Old June 20, 2011, 09:31 AM
Default I5 750 issues with OC
Hi there,
I have had my 2.66ghz running at 3.33ghz forever with no issues. That was on a ga-p55-ud4p with xp. I had two sticks of ram in it, 2gb each. They're ripsaw, dual channel, 1.65V written on the actual sticker on the diimms but I think the bios always shows them at 1.5V
Anyway...I go to Windows 7 64 bit and add two more sticks(they are all identical) So....that's 4 sticks x 2gb. The machine will post but will not enter windows. It just hangs with the small, while flashing underscore near the top of the screen. However, If I set her back to default, 2.66ghz, all is well. Windows 7 boots, 8gb registers...but...no more 3.33ghz cpu?
Any thoughts on how or if I can work this out?
thanks.
Old June 20, 2011, 10:19 AM
maverick_brent's Avatar
Bump up your dimm and imc voltages take the dimm to 1.65 or 1.7 and bump the imc up a notch or two from its default
Old June 20, 2011, 10:50 AM
absolutely, up the voltages on the ram to at -least- spec, if not slightly more
Overclocking I5 750 Behemoth- Overclocking, Tweaking and Benchmarking 2 March 15, 2010 06:43 PM
-bigadv on a I5-750 ??? MarkOne HardwareCanucks F@H Team 27 February 4, 2010 04:35 PM
[WTB] I7 860 or i5 750 matsta31 Buy/Sell & Trade 0 February 1, 2010 12:23 PM
Which is the best? 750 or 860 MarkOne Overclocking, Tweaking and Benchmarking 6 December 31, 2009 06:40 AM
i5 750 @ 4ghz Fudd Rucker Overclocking, Tweaking and Benchmarking 4 December 16, 2009 12:56 PM
