<~----> Difference between OC'd Q6600 and stock Q6700, etc... - Hardware Canucks
Old February 4, 2008, 01:17 PM
Default Difference between OC'd Q6600 and stock Q6700, etc...
I have just found myself a new $$$$ hobby. I am in the process of building a new gaming system and I am at the point where it's time to buy the CPU. I was wondering if an OC'd Q6600 to say 3.2 GHZ is faster than a stock Q6700. Is the the Q6600 and the 6700 basically the same chip just clocked differently or is there more to the chip it self that makes a difference?
Old February 4, 2008, 01:18 PM
just clocks.
Old February 4, 2008, 01:20 PM
DaBruuzer's Avatar
I have the Q6700, and it is basically the same CPU with different clocks. However, my multiplier runs stock at 10x, and I believe the Q6600 is at 9x. Not sure what difference that makes in the end, though.
Intel Core 2 Quad Q6700 @ 3.2GHz
Gigabyte GA-P35C-DS3R
OCZ Vendetta CPU Cooler
OCZ Reaper HPC 4GB (2x2GB) DDR2-800
XFX GeForece 8800GTS 512 (G92)
WD SE16 500GB SATAII / WD 250GB SATAII
LG SATA DVD-RW
Corsair HX520 Modular PSU
Antec P182 w/all fans replaced w/Noctua NF-P12-1300s
BenQ T221W 22" LCD @ 1680x1050
Logitech X-540 5.1 speakers
Vista Ultimate 64-bit
Old February 4, 2008, 01:24 PM
at what point or chip, starting from the Q6600, does it not become clocking as the difference and the chip itself? Is it once the first number changes (ie Q6600, Q6700, Q9300 etc..) and once it goes from 65nm to 45nm?
Old February 4, 2008, 01:28 PM
DaBruuzer's Avatar
Well, the Q6600 and Q6700 are the only mainstream (read NOT Xeon) quad-core processors from Intel at the moment, besides their "extreme" QX-series (basically the same CPUs, clocked higher and with unlocked multipliers, I believe). Their 45nm quad-cores have been delayed again, but should be out in the near future, and are the Q9XXX-series.
LG SATA DVD-RW
best way to test an OC'd gpu djnocide Video Cards 8 February 26, 2008 08:47 AM
Wow.. Big difference Infiniti Water Cooling 8 December 25, 2007 07:24 PM
WD Raptor - Big Difference? Worth it? zlojack Storage 17 December 18, 2007 04:27 PM
OC'd a little 2 much me thinks. neophyte33 Overclocking, Tweaking and Benchmarking 8 December 2, 2007 12:30 AM
What's the difference between Q6600 and Xeon 3220? r00tman CPU's and Motherboards 13 June 21, 2007 05:41 PM
