  #71 (permalink)
Old October 18, 2012, 05:08 PM
Perineum's Avatar
Samsung is famous for it's crappy caps in it's PSUs for computer LCD panels. Mind you, once you recap them they usually run.
I'm recapping a 245BW now and digikey sent my caps and resistors in about 40 hours from the time I submitted the order.
  #72 (permalink)
Old October 18, 2012, 05:14 PM
Pentium_5's Avatar
Yeah, they seem to either have CapXon or Samwha which are also pretty bad. Wow, you're lucky! It takes about a week to get my stuff from Digikey so I order a lot of stuff at once.
  #73 (permalink)
Old October 18, 2012, 06:22 PM
Perineum's Avatar
All these are Samwha - the black marks on top are from my felt marker.... Just marks to make sure I don't miss ordering a cap
The 3 resistors in the foreground are burnt and in the cluster of caps on the right side the two leftmost are domed.
Mind you all of them are probably bad. I don't even test, I just shotgun them all with new panny FM or FC's
  #74 (permalink)
Old October 18, 2012, 06:30 PM
Before you place your order, check all of the fuses and the MOSFETs on the back (depending on the pcb revision). I have two Samsung IP-35135 boards, one A and one B, both with different parts that failed.
My A board has a blown MOSFET, and my B has a blown Picofuse.
Lots of details can be found on Badcaps.net
heatware
  #75 (permalink)
Old October 19, 2012, 01:28 AM
Perineum's Avatar
It fired right up after the resistor and cap swap.
Unfortunately I had to reuse the large 450v cap because I screwed up on the replacement - I got 30mm tall, not 30mm wide. D'oh!
The cap tests at the right capacitance, but I have no way of knowing ESR at this point.
zoob: I've been on badcaps.net for a couple years now...
  #76 (permalink)
Old October 22, 2012, 12:57 PM
Pentium_5's Avatar
More dead CapXon from a Samsung monitor and unfortunately some dead Ruby's from an Intel 775 board :( it had 30,000 running hours though and terrible air flow
  #77 (permalink)
Old October 22, 2012, 01:09 PM
Pentium_5's Avatar
Pic #1: Dead Ltec from a Dell PSU, LiteON OEM
Pic #2: Bulged JEE caps from a Sun Pro. Almost all of them were domed or leaking
Pic #3: Popped YC caps from yet another terrible L&C, all of them were bulging
Pic #4: Wow...look at all those dead Sacon's. Big surprise!
  #78 (permalink)
Old October 22, 2012, 01:36 PM
Soultribunal's Avatar
Ironically all these dead cap threads reinforce is you get what you pay for.
You buy a high quality board/PSU etc etc, you are usually golden. Otherwise, see above.
-ST
www.realhardwarereviews.com
  #79 (permalink)
Old October 22, 2012, 02:05 PM
Pentium_5's Avatar
-ST
Exactly These are just components that I see come in at work.
  #80 (permalink)
Old October 23, 2012, 05:53 PM
Fixed a dead Samsung 701N. Replaced the bad bulgy Samxon caps, replaced two SP8M3's as per a thread about the IP-35135A PSU... Woohoo! Excuse my SMD soldering. I had my hot air pencil too hot and separated the layers by accident...
heatware
All 8800GT Pictures Gallery ..'Ant'.. Video Cards 15 December 22, 2007 06:30 AM
First pictures of Nvidia MCP73 motherboard Babrbarossa Press Releases & Tech News 4 August 19, 2007 09:45 PM
R600 pictures Babrbarossa Video Cards 6 March 20, 2007 09:05 AM
680i DEAD DEAD DEAD sizerkozak CPU's and Motherboards 29 February 9, 2007 10:08 PM
Pictures of your rig setup Supergrover Off Topic 0 February 9, 2007 09:25 PM
