  #101 (permalink)
Old September 15, 2013, 02:57 PM
trodas's Avatar
Entilza -
So do the higher quality sealed top caps ever fail?
The smaller electrolyte caps did not have the perfored vents too, but it does not mean that they cannot fail. They do fail. The polymers (the new, "higher quality" caps) are w/o the electrolyte, so they are supposed to hold better. But the companies rate them at 2000h with 105C too, same as quality elytes.
(that figure 200h at 105C means that when you cool them down to 45C, then they are guaranteed to hold up for 14,6 years)
However under stress and bad caps from PSU even the polymers fail badly. Check there:
Horrible pictures of dead caps
Not only ECS boards had bad caps... and not only that bad caps are always the same - server mainboard, Dell Precision 450 with Nichicon caps, user markp, OC AU firum - yes, this is the infamous bad batch of the Nichicon caps ;)
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
  #102 (permalink)
Old September 15, 2013, 03:05 PM
trodas's Avatar
Asia-X caps in OCZ PSU, user spyder from BadCaps forum
  #103 (permalink)
Old September 15, 2013, 03:08 PM
trodas's Avatar
K7NCR18D pro2 mobo with GSC caps, user Grings from TechPowerUp forum
  #104 (permalink)
Old September 15, 2013, 03:15 PM
trodas's Avatar
Entilza - something for you: Asus P5K-E - exploded Fujitsu polymer cap 270uF 16V in the Vcore input filter phase:
Why? Because user NewBeetle from Xtremesystems forum overclocker with OCZ PSU, only 520W and full of Teapo caps...
Please note the capacitor explosion of P5K-E
(besides, the input caps for Vcore filter are - according to the electrolyte caps specs verzus polymers - suboptimal and quality hi-capacitance electrolytes works better there, even Intel O/C designs used them... yet todays the marketing dictate to use polymers everywhere, so... not exactly good after all....)
  #105 (permalink)
Old September 15, 2013, 03:24 PM
trodas's Avatar
Zotac 7300GT gfx card, Sacon caps, user vlask, SHW forum
PS. Zotac "fixed" gfx card the way it cought on fire: http://www.svethardware.cz/forum/showthrea...ll=1#post283635
...and the quess what! Zotac refused to acknowledge that it is their fault and because it label it as "physical damage", it the refused RMA! Of course when card caught fire, it is physical damage, you... But the user just played a game, not burned the card inside of running PC, because he want to kill it...!
  #106 (permalink)
Old September 22, 2013, 09:49 AM
trodas's Avatar
HP Pavilion, TMS caps, user crazy4offroad, Abit forum
  #107 (permalink)
Old September 22, 2013, 09:50 AM
trodas's Avatar
MSI mobo 6163 with Chhsi caps, user mech13, SvetHardware.cz forum
  #108 (permalink)
Old September 22, 2013, 09:58 AM
trodas's Avatar
Unknown mainboard and user, found on BadCaps forum, YEC caps
  #109 (permalink)
Old November 29, 2013, 10:31 AM
Dr_BenD_over's Avatar
Fallen Folder
I just resurrected this circa 2006 Dell E6300...
Bad caps were all UCC.
All's well that's Haswell
  #110 (permalink)
Old February 13, 2014, 07:41 AM
Fallen Folder
Samsung 206BW LCD, CapXon capacitors
All 8800GT Pictures Gallery ..'Ant'.. Video Cards 15 December 22, 2007 06:30 AM
First pictures of Nvidia MCP73 motherboard Babrbarossa Press Releases & Tech News 4 August 19, 2007 09:45 PM
R600 pictures Babrbarossa Video Cards 6 March 20, 2007 09:05 AM
680i DEAD DEAD DEAD sizerkozak CPU's and Motherboards 29 February 9, 2007 10:08 PM
Pictures of your rig setup Supergrover Off Topic 0 February 9, 2007 09:25 PM
