Old February 2, 2008, 01:12 AM
BALISTX's Avatar
Level up: 54% Level up: 54% Level up: 54%
Level: 21 - 564 points to level up
Default Helping a Friend OC GA-P35-DS3L
Well as some of you may know I sold my old E2180 rig to a friend at work. Now comes the time for us to OC it. Currently he is running at stock. I have a theory that I want to run past those how have more experiencing OCing the Gigabyte GA-P345-DS3L motherboard.
Before I get into my theory here is the system specs.
Intel E2180 (M0 stepping)
Gigabyte GA-P35-DS3L (rev 2 I think) BIOS will be flashed to F8a
4GB of Mushkiin HP2-6400 4-4-4-12
XFX GeForce 7900 GS XT (Upgrading to an 8800GT 512MB)
CPU HSF AC7 Pro
Here is my theory. We want to keep the memory as close to running at 800MHz as possible and his goal is a modest 2.6-2.7 OC (Which I achieved 2.75 - 275x10) What i want to do is try 400x7=2.7GHz and I know from seeing other people and other reviews that this board can run a FSB of 400MHz. With that being said. We can then set the Memory multi to 2 and that will give us a memory freq of 800MHz.
Does my theory sound like it will work?
If so will the AC7 be enough to cool the CPU
Will I have to up the vcore?
Will I have to up the NB voltage?
We will try and cool the NB with a 40mm fan.
Currently there are 3x120mm and 1x80mm fan in the case.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
BALISTX.com
Old February 2, 2008, 09:55 AM
CPU HSF AC7 Pro
Just checking something isnt 400x7=2.8ghz ?
Old February 2, 2008, 10:05 AM
3.0charlie's Avatar
  • Your Theory: looking good.
  • AC7: yes, more than enough. As always, keep an eye on the temps.
  • Vcore: maybe, but not by much.
  • VFSB: + 0.1V probably.
  • NB block: definitely cool that NB.
400MHz x 7 is 2.8GHz, which can be done rather easily with the setup, and the 2x Ram multi from the new F8a BIOS will surely help. And remember that your HP2 can run upto 500MHz.
Have fun!
edit: I forgot to add that I built a rig last Monday with an E2140, 2x1Gb OCZ Gold, Gigabyte G31-S2, AC7 and a Coolermaster 650W. 2.8GHz was easily reached w/1.35V VCore (vid was 1.33). That was just before having issues with the onboard video and some artifacts popping up...
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old February 2, 2008, 01:31 PM
BALISTX's Avatar
John, thanks for the info. I was pretty sure that would work. We will give this a shot on Monday. How much do you think the vcore will be need to upped? The current vcore I believe is 1.20 or 1.25, so maybe up it to 1.30?
Yes and 400x7 is 2.8. It was 3am when I wrote that and I was tired LOL.
[Heatware]
BALISTX.com
Old February 2, 2008, 01:39 PM
3.0charlie's Avatar
The E2140 that I installed had a rather high Vid of 1.33. At stock, 2.6GHz was reached and tested as stable with 2 hours OCCT. 2.8GHz needed 1.35V (up by 2 settings in the BIOS) to be stable 2 hours OCCT. I didn't need more testing since this rig will be mainly used for surfing and using the Office Suite.
Old February 2, 2008, 01:48 PM
BALISTX's Avatar
Not a bad OC. I want to get another DS3L board with a E8400 and a set of 4GB Mushkin XP Redline PC-8000. My goal is 500FSB x 8 = 4.0GHz and setting the mem multi to 2 to get 1000. I know I could a set of HP2-6400 and push them to run at 500 like you said earlier but I'm not a huge fan of pushing memory. What do you think.
Cooling wise I doubt an AC7 would be sufficient enough to cool the CPU.
[Heatware]
BALISTX.com
Old February 2, 2008, 01:54 PM
3.0charlie's Avatar
Actually the oc was limited by artifacts from the onboard video... that chip could have gone faster.
As for your E8400-DS3L combo using the AC7, I don't know. I haven't played with the E8400 to compare its heat output. The AC7 is a great little HSF, but it has its limits. Ram-wise, using the 6400 is the luck of the draw. But you'll need some hefty voltage for 500MHz - 2.2, 2.3V. That's why I'm shopping for some PC2-8500...
Old February 2, 2008, 01:56 PM
BALISTX's Avatar
On second thought instead of buying new ram, I could atempt this: FSB 450x9 wich would run my CPU at 4.0GHz and my mem at 900 using the 2 mem multi. John, do you think those EM-6400 can handle 450MHz?
[Heatware]
BALISTX.com
Old February 2, 2008, 02:01 PM
3.0charlie's Avatar
Yes Sir, they can.
Old February 2, 2008, 02:07 PM
BALISTX's Avatar
Sweet, I can save some coin. What was vdimm set to with the EM's? Did you put any additional cooling. I think my case will be sufficient enough cooling. I will have 6x120mm fans. I can then take that extra money and get a TRUE 120.
[Heatware]
BALISTX.com
GA-P35-DS3L OC Time! Prof. Dr. Silver CPU's and Motherboards 149 May 29, 2008 12:06 PM
New comp for a friend. belgolas CPU's and Motherboards 7 March 12, 2008 09:04 PM
Ga-p35-ds3l mgp141 CPU's and Motherboards 3 January 8, 2008 11:59 PM
USB thumb drive helping with boot speed? Robscix O/S's 13 January 6, 2008 07:27 AM
Friend(ly) Network Mysteryous Networking 16 September 13, 2007 07:36 AM
