  #31 (permalink)
Old February 7, 2008, 12:21 PM
3.0charlie's Avatar
Originally Posted by overkill View Post
Bumped the mem up to 866. running solid, noticable improvement over the 780. Left the mem timing at auto, Charlie what mem you using at 1000. I'm not using any ram cooling right now.
Mushkin EM2-6400, 2.2V. Spot Cool fan next to the sticks.
Hydro-Quebec is salivating...
  #32 (permalink)
Old February 7, 2008, 02:11 PM
overkill's Avatar
Default mem clock
Thanks man...thinkin on pushin her a little further
  #33 (permalink)
Old February 7, 2008, 02:14 PM
3.0charlie's Avatar
Try dropping the multi to 9, instead of 10 - you may be able to raise the FSB higher.
  #34 (permalink)
Old February 7, 2008, 02:48 PM
BALISTX's Avatar
I think once we get some sufficient cooling on that memory and NB we could set the FSB to 300 x 9 put the CPU to 2.7 and set the Mem Multiplier to 3x so the memory will run at 900MHz and then go in a start tightening the timings. Maybe try them at 5-5-5-18. What do you think John?
  #35 (permalink)
Old February 7, 2008, 02:54 PM
3.0charlie's Avatar
Or even 8x 350FSB. Better for Ram clocking. As for the NB, just slap a fan next to it.
GA-P35-DS3L OC Time! Prof. Dr. Silver CPU's and Motherboards 149 May 29, 2008 11:06 AM
New comp for a friend. belgolas CPU's and Motherboards 7 March 12, 2008 08:04 PM
Ga-p35-ds3l mgp141 CPU's and Motherboards 3 January 8, 2008 11:59 PM
USB thumb drive helping with boot speed? Robscix O/S's, Drivers & General Software 13 January 6, 2008 07:27 AM
Friend(ly) Network Mysteryous Networking 16 September 13, 2007 06:36 AM
