Old May 30, 2011, 09:53 AM
gingerbee's Avatar
Default what the hell
ok well my bclk lowers when setting my multi wow cause so far i can't overclock my 2600k at all and i am using a sabertooth p67 b3 so any help i have been overclocking for years my guess is i am missing something simple
Old May 30, 2011, 10:24 AM
ipaine's Avatar
So when you go into the bios the only thing you change is the multi and when you go into windows the bclk is lower?
Just want to be sure.
Also maybe just try the OC tuner within the BIOS to see what it comes up with for you. It is under the AI tweaker tab in the bios.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old May 30, 2011, 10:33 AM
gingerbee's Avatar
yup thats it and when i try the oc tuner it does nothing. kinda weird eh
Old May 30, 2011, 10:52 AM
gingerbee's Avatar
even if i set the multi to 100 it changes which is nuts to me
Old May 30, 2011, 11:12 AM
Never had this problem with my Sabertooth P67 B3. Clear the CMOS and see if it is still doing this. Also, make sure the board has the latest BIOS as well, although the B3s should have all shipped with the most current one (at the time).
Old May 30, 2011, 11:27 AM
francisw19's Avatar
Very strange...I've had no such issues on my Sabertooth P67. Have you tried maually entering 100 MHz as the base clock in the BIOS?
Old May 30, 2011, 11:28 AM
gingerbee's Avatar
it does not sure whats up but will do. kinda strange eh
What the hell is going on?! encorp Off Topic 18 November 4, 2010 12:43 PM
ok what the hell is going on over at ncix. gingerbee Off Topic 31 June 11, 2010 11:34 AM
WHITE HELL _dangtx_ Off Topic 26 January 29, 2010 02:26 PM
Printers are from hell Jake_HT Off Topic 30 January 18, 2010 09:25 PM
If You Laugh You're Going to Hell geokilla Off Topic 11 October 23, 2009 10:47 AM
