Old May 16, 2011, 02:38 PM
gingerbee's Avatar
Default I3 540 wow overclock on air
Well like the title states i just want top share this pretty damn decent for air just got my hands on this and think i may rock it for awhile over my zeon. just cause i can
Old May 16, 2011, 03:44 PM
the 23 multi helps a WHOLE LOT ;)
drop it to 22(aka i3 530) and s
Old May 16, 2011, 05:56 PM
gingerbee's Avatar
i could go higher just really don't need to and why would i drop it when i can use it at that speed my point is that most have trouble getting above 4.4 on air or below anything then 1.45Vcore
Old May 16, 2011, 06:41 PM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
Yeah, like I showed in my review, a Core i3-540 @ 4.6Ghz is a very potent little chip.
I would still heartily recommend one over any of the non-overclockable dual-core Core i3-2100 series 'Sandy Bridge' processors.
Old June 3, 2011, 11:58 AM
MARSTG's Avatar
Ok, in order to ovc one of those chips, specifically the core i3 2100, which has a locked multiplier, what chipset do i need to look for on the mobo? I guess something from the P series, something that does not have any possibility of using the integrated graphics I guess? P67 would be a good starting point? And how much can we go just on air for the i3-2100?
Old June 3, 2011, 12:07 PM
MAC's Avatar
MAC MAC is offline
There's no point attempting to overclock a locked Sandy Bridge chip.
You are only going to get a 5-6% overclock since that is all the BCLK allows.
Hence why I said I recommend the older Core i3 LGA1156 chips instead.
Old June 3, 2011, 12:12 PM
if you go over 5 in terms of stock bclk on any locked sb chips? youre doing good :D
7 ghz overclock wow Shadowmeph Press Releases & Tech News 8 November 16, 2009 09:57 AM
The Official Hwc Air-cooled Overclock Compare Adn Discussion Thread cadaveca Air Cooling 0 November 16, 2008 10:33 AM
Yorkfield overclock on air! INSANE! Wankerfx Press Releases & Tech News 18 December 7, 2007 02:01 PM
