Old May 12, 2011, 07:31 PM
On2wheels's Avatar
Default EVGA Precision not loading at boot
Running version 2.0.3 on my GX560Ti, with forceware drivers 270.61 and have the checkbox ticked to 'start with windows' and to display temps in the tray only, but nothing appears in the sys tray at bootup, even running the app manually doesnt show the temp there, and checking my startup progs with CCleaner shows nothing.
Are you guys aware of any bugs with 2.0.3 or am I unlucky? All i mostly use it for is proper fan control, is MSI Afterburner better at it?
running Win7 64bit.
Old May 12, 2011, 08:57 PM
francisw19's Avatar
I haven't used precision in ages, so I don't know if they've implemented any new fan control features. However, I'm using Afterburner on my GTX560Ti's and the fan control is really good. You can set a fan curve in the settings (fan speed vs. temp).
I have no problems with Afterburner...maybe give it a try.
Old May 12, 2011, 10:17 PM
Mook06's Avatar
reinstall the program, right click run as administrator, also you can try adding a shortcut to the prog to the startup folder in your start menu, but this wont help if the program doesnt even start manually
Old May 13, 2011, 09:16 PM
On2wheels's Avatar
It does start manually, just didn't work properly. Running Afterburner now, looks awfully similar to Precision setup window! But it's got a nice big graph.
Old May 14, 2011, 09:56 AM
francisw19's Avatar
Yup...afterburner should look familiar. It's developed by the same guy that makes RivaTuner and Precision. ;)
Old May 14, 2011, 12:20 PM
sswilson's Avatar
Yeah.... Afterburner is my current "go to" GPU OC app. The only benefit I've heard of for precision over AB is that precision allows the shaders to be de-linked, but I haven't personally seen proof of that.
Old May 15, 2011, 06:22 PM
rjbarker's Avatar
Been running Precision for a few yrs now, no issues at all. Sounds like your missing something in the set- up.
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Boot up time slow Prior to loading Windows Skychan CPU's and Motherboards 8 April 11, 2011 09:31 AM
eVGA Precision 1.9.1 r0k0 Overclocking, Tweaking and Benchmarking 12 February 12, 2010 06:08 PM
EVGA Precision v1.8.0 Update FiXT Press Releases & Tech News 1 August 19, 2009 10:04 AM
EVGA Precision 1.5 released Alwaysrun Overclocking, Tweaking and Benchmarking 3 March 8, 2009 11:16 AM
EVGA Precision - Crysis element291 Overclocking, Tweaking and Benchmarking 12 January 28, 2009 03:41 PM
