-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   OC for Chimp Challenge (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/43196-oc-chimp-challenge.html)
xilocient May 10, 2011 02:30 PM
1 Attachment(s)
So I finally got around to OCing my computer for the Chimp Challenge. In order to save time and gain more points for the team, I used the auto overclocker in the asus BIOS on my MB.
Since It's my first time, I want to make sure I won't be killing my computer by running it 24/7 at these clocks.
I've got my i5 750 running at 3.7 GHz with a Vcore of 1.3 V. Temps are stable with 24/7 folding in the low 60s.
My 5870 is running at 960/1300 and is stable in the low-mid 80s.
Other than generating a bunch of heat, will these settings cause me problems for the next 5 days or so?
_dangtx_ May 10, 2011 02:45 PM
1.3 is mighty fine,no worries :)
go go go!!!!
SugarJ May 10, 2011 03:23 PM
Those temps are fine, although you may want to up your fan speed on the GPU.
