Originally Posted by LarkStarr higher NB, PLL and termination voltages, push 1.47v on the cpu, the rather large droop should make up for it anyways. check your ram speed and timings as well in correlation to the FSB speed. have you dropped the divider? |
I was told the termination voltage should not be put any higher than 1.3.
Raising the NB and PLL voltages from 1.4 and 1.5 don't seem to help. Plus, I only have two options for PLL voltage, 1.5 and 1.7. I think 1.7 is a little high.
I don't really understand how RAM speed/timings and dividers work, so I didn't do much with that. Right now, at DDR2-902, 4-4-4-12, 2.0v (had to raise this due to multiple blue screens), I have an FSB:DRAM ratio of 2:3.
