Old April 29, 2011, 08:38 AM
Default OpenCL (CPU + GPU) Benchmark
Here I would like to show the HardwareCanucks Forum the benchmark I wrote in C# and OpenCL. The algorithm consists of calculating the orbital trajectory of 1000000 rocks around a sphere in space using Kepler's laws of planetary motion and the formula of an ellipse. The is in loop which repeats itself 1000 times. The benchmark can both be executed on the CPU and GPU. The CPU and GPU benchmarked are multi-threaded.
If enough people show interest in this benchmark then I will create a highscore list. Please post your results with a screenshot of the results.
I have a Radeon HD 5870 GPU and the GPU benchmark currently does not work on my GPU. I am using the Catalyst 11.4. The benchmark might work with an earlier driver and the AMD Stream SDK. Geforce users should have no problem executing the GPU benchmark as long as their GPU driver is up to date.
Here is my result for the CPU benchmark.
Old April 29, 2011, 08:44 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
VERY cool.
The issue may be the change from AMD's Stream to the AMD APP platform though. Have you tried their newest SDK?
Old April 29, 2011, 08:55 AM
Fudd Rucker's Avatar
Crashes when I try to run the GPU benchmark. Have updated drivers.
I couldnt think of something snarky or interesting to put here this time around.
Old May 4, 2011, 05:04 PM
same thing for me, CPU work fine but you must close and re open the app to reset testing
GPU crashes
Old May 4, 2011, 06:54 PM
Crashes for me as well on the GPU test, works fine on the CPU Test.
CPU to GPU? Fudd Rucker Water Cooling 15 March 8, 2010 01:19 PM
OpenCL/Ageia, nvidia/ati opinions? gtx260 vs. hd5770(+9600gso) 0o0 Video Cards 1 December 20, 2009 03:49 PM
CPU and gpu charts MarkOne HardwareCanucks F@H Team 13 December 14, 2009 03:42 PM
ATI HD 5900 Series Video Cards Foreseen in OpenCL Update FiXT Press Releases & Tech News 10 October 16, 2009 10:21 AM
Cpu, Gpu or what? upgrade? phil3_66666 CPU's and Motherboards 12 March 14, 2009 05:54 PM
