Old April 11, 2011, 04:37 PM
Wurmer's Avatar
Default Strong will system
Ok I got my new rig running nice and smooth but for one thing, it simply refuses to get OC'ed no matter what. It won't even let EVO auto tunning OC it a bit. I had this software running on my AMD rig and it was working decently well, meaning that I could get from 3.2 to 3.8 without any hassles.
With this system the minute I try to OC it with EVO it freezes no matter what, I tried to do it manually but I was too aggressive and had to use the jumper to clear CMOS. I don't know maybe it doesn't like my ram which are Hyper X 1600 9-9-9-24 1.65v.
Any idea
Old April 11, 2011, 05:02 PM
so if you up them multis its a no go?
go the lazy way and give it 1.35vcore, 1.3 vtt right off the bat.
Old April 11, 2011, 05:10 PM
Wurmer's Avatar
I had 1.3 on the core and had 100x44, this work for a little while than crashed.
Old April 11, 2011, 05:40 PM
Wurmer's Avatar
Ok it's now running at 4.0 Ghz but under prime temps seem to be high like 68-75 !
Old April 11, 2011, 05:47 PM
stock cooler?
keep going slowly slowly.maybe set mem timings manually or drop ram speeds, even though
youre not touching the good ole bus to oc..:)
also remind me why the 2600k vs the 2500k? :)
Old April 11, 2011, 06:18 PM
Wurmer's Avatar
Originally Posted by _dangtx_ View Post
stock cooler?)
No saddly not, I am using an Hydro 50 that's why I think my temps are way too high.
Old April 11, 2011, 06:24 PM
All you should have to do is set your CPU voltage to 1.3v and your ram to whatever it says on the side or manufacturers specs then just slowly up the speed.
I ran a 2600k on a h50 overclocked and it was fine.
68-75 is too tho and should be lower.. I'd check your fan arrangement on the H50 or reseat it.
Old April 11, 2011, 06:36 PM
Wurmer's Avatar
Ya it's probably something like that, I will reseat it. it doesn't say much but my idle temps are ok like 24 through 31
Old April 11, 2011, 07:01 PM
the h50 is not exactly the king of coolers, so those temps under certain conditions might be within the normal range.
Old April 11, 2011, 07:04 PM
Unless you've used one..
Banana Grove To 10 Ft and Going Strong! rjbarker Off Topic 16 July 25, 2010 03:32 PM
What are you buying with our strong loonie? deathsupport Off Topic 18 April 10, 2010 07:47 PM
Strong CDN$$$ ... rjbarker Off Topic 22 October 14, 2009 05:19 AM
The Boycott Against Activision Growing Strong LionRed Gaming 29 August 12, 2009 03:55 PM
PSU strong enough FrankyG Power Supplies 1 January 11, 2008 01:10 PM
