Old April 10, 2011, 06:54 PM
r0k0's Avatar
Default Power Supply Question
So yeah, i've just check my PSU information sticker and i have 4 rails of 16amp each....
i've read somewhere those we're to worst for overclocking right ?
i've check local and they have a Coolermaster Silent Pro M1000 / M850 Modular with a Single rail of 80amp
So either 850W or 1000W which would be best for OC / Gaming and BTW only 20$ Difference between both
Silent Pro M 1000W - Cooler Master
Would this help me out a little ?
thanks
P.S Replacing PSU is my next priority since my i getting loud as hell :(
Intel i7 3930K / 16GB Corsair Vengence DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 770
Corsair 480GB SSD / 1TB WD Black
IN WIN 303 / EVGA NEX750 Gold
Old April 10, 2011, 07:11 PM
3.0charlie's Avatar
Which store is local to you?
Hydro-Quebec is salivating...
Old April 10, 2011, 07:21 PM
r0k0's Avatar
Canada Computers
Old April 10, 2011, 07:28 PM
3.0charlie's Avatar
I'd go with either of those, before buying a CM PSU.
Enermax Revolution 85+ 920W Power Supply (80+ Silver Certified) (ERV920EWT) | Canada Computers
Enermax Revolution 85+ 1020W Power Supply (80+ Silver Certified) (ERV1020EWT) | Canada Computers
I used the 920W with the SR2 I had, great PSU.
Old April 10, 2011, 07:37 PM
r0k0's Avatar
but its still a Quad rail PSU... aint single rail better than quad for optimum gaming ?
Old April 10, 2011, 07:44 PM
3.0charlie's Avatar
Don't worry about them rails. The 'max 920W ran perfectly while folding on the SR2 (100% load, on 2 CPUs). But if you really want single rail, I'd go with the Antec AX750 / AX850.
Old April 10, 2011, 07:52 PM
r0k0's Avatar
AX850 is 209.99$ :P the Coolermaster 850 is 129.99$ why is coolermaster bad ?
Old April 10, 2011, 07:58 PM
3.0charlie's Avatar
The PSU you chose is a 2009 Bronze model. You don't need 1kW for your rig, and as of today there are far better units efficiency-wise than the 850W. For example the Enermax's I linked.
Old April 10, 2011, 08:00 PM
r0k0's Avatar
its still 60$ more expensive with a 30$ mail in rebate
p.s power saver i dont care i have power included in rent i can spend as much power i want :P
Old April 10, 2011, 08:09 PM
Arinoth's Avatar
Question, why do you need that much power for a power supply? Are you planning on running 2-3 cards, if not you're essentially wasting your money as one card will never require a near 1kW psu
Here I am: here I remain
Power supply and UPS question r0bc Power Supplies 9 December 7, 2009 08:31 PM
[WTB] power supply 650+ power supply j-ronde Buy/Sell & Trade 1 March 31, 2009 09:45 AM
