Old March 29, 2011, 04:45 PM
Alpine's Avatar
Default Help for a OC I7 2600k
I need help to OC a I7 2600 with a Gigabyte P67-UD4-B3....
I was able to get 4.5 20 hrs straight. now, im not able to get anything....
I always have BOSD with code 124 which is QPI Voltage. I did have give it always +1 and + 1 but now im at 1.42.
Any help will be very welcome, here my settings for the moment....
Load line Calibration: Enable
PPL Overcharge: Enable
BulCK: 99.98Mhz
Multiplier: 45
CPU Vcore: 1.30
QPI/VTT Voltage: 1.42 should i add again ??!
System Agent Voltage: 0.92
dram vOLT: 1.56
draM VREf: 0.72
PCH Core: 1.05
CPU PLL: 1.80
• ► › I7 3930K|Asus P9X79 WS|Evga GTX 690 Signature|Corsair Force 3 120GB|Corsair H1000|Corsair Dominator Platinium 16GB 2133Mhz|
Corsair AX1200|Corsair 600T SE|Corsair SP2500|Corsair Vengeance 2000
• ► › I7 2600K @ 4.9Ghz|P67A-UD4-B3|12G G.Skill 1600Mhz|Noctua NH-D14|OCZ Vertex 2 60GB|EVGA GTX 580 SSC|Corsair AX650|Lancool PC-K62|
Old March 29, 2011, 04:58 PM
G777's Avatar
Not sure about the bsod code, but looks to me like you need more vcore. I have an Asus board and vccsa/vccio voltages are no where near that high.
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
Old March 29, 2011, 05:00 PM
Give us information about your DRAM timings and speed. It could be your DRAM limiting your o/c... I highly suggest keeping your voltages MUCH lower than X58 as SNB is weaker to high voltages (You will kill your chip faster with voltages close to normal X58 o/c).
Stay below 1.35v vcore for sure, and VTT I am not so sure, but I'd say to try and stay below 1.4v
Old March 29, 2011, 05:05 PM
Alpine's Avatar
My ram is Gskill DDR3 1600Mhz Ripjaws running at 1600Mhz, no OC on them....
Im gonna drop kid to bed and come back in few mins....
Old March 29, 2011, 05:06 PM
3.0charlie's Avatar
I clocked a 2500k last night to 4.7GHz (under 70c with a TT Frio, and LinX 20 passes stable at Max. memory) only raising the Vcore to 1.355V, nothing else. I think too that your Vcore is low for 4.5.
Old March 29, 2011, 05:12 PM
Load line Calibration: auto?
also, decrease qpi speed? :)
hate that bastard :D
Old March 29, 2011, 05:17 PM
Alpine's Avatar
im gonna look over the web if i can find something about the BOSD CODE 124 to see it is really...
Old March 29, 2011, 05:50 PM
I'm stable at 4.5GHz on my 2600k at around 1.24V, I've set it to offset + mode and this is what it hits at load.
I've stress tested for 4 hrs on Prime95, I feel that's sufficient enough to have a stable OC.
Old March 29, 2011, 06:04 PM
Alpine's Avatar
i was at
BulCK: 99.98Mhz
Multiplier: 45
CPU Vcore: 1.35
QPI/VTT Voltage: 1.20
dram vOLT: 1.56
draM VREf: 0.72
PCH Core: 1.05
CPU PLL: 1.80
and crash 45 mins later
Old March 29, 2011, 06:21 PM
I clocked a 2600k to 4.5ghz by doing nothing but setting DRAM voltage to 1.65 and CPU voltage to 1.30
Turned on low vdroop.
WIP I7 2600K build... Alpine Case Mods, Worklog & Gallery 17 April 3, 2011 02:32 PM
2600k Overclocking Wi-Fuzzy Overclocking, Tweaking and Benchmarking 16 March 27, 2011 06:09 PM
Questions... i7-2600k vs SR-2 Grampa HardwareCanucks F@H Team 29 March 11, 2011 04:21 AM
2600k benchmark botat29 CPU's and Motherboards 12 January 17, 2011 02:03 PM
Intel i7-2600k Zink HardwareCanucks F@H Team 19 January 7, 2011 12:39 PM
