  #31 (permalink)
Old March 29, 2011, 08:27 PM
Alpine's Avatar
i will do a RMA this week, i send them a email
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
  #32 (permalink)
Old March 29, 2011, 08:46 PM
Your gonna send them an RMA because their software doesn't work properly?
If your in the bios and change the QPI voltage does it affect the VCORE voltage?
  #33 (permalink)
Old March 29, 2011, 08:52 PM
G777's Avatar
Are you reading his posts, or just randomly commenting?
"this is the same in the bios. When i play with the Vcore in fact it change the QPI. and when i play with the QPI the Vcore change"
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
  #34 (permalink)
Old March 29, 2011, 09:02 PM
Yes I'm reading his posts.
I am curious of how he is getting this idea.
Is he watching the bios or depending on the Gigabyte software for his answers.
  #35 (permalink)
Old March 30, 2011, 01:37 PM
Trial Member
Hey guys - Just registered to advise that there is nothing wrong with the board etc - CPUz reads QPI voltage on the B3 Gigabyte boards, it will get fixed in time. Try Aida64 it tells you the voltage is 2.9v for cpu or something >.>
HWinfo32 and the ET6 application are correct as per bios (obviously not as good as a multimeter).
In regards to the overclock... it sounds like you may be capped at 4.7 ish, certainly most can hit 5ghz with 1.4 but there will be chips on both sides of that. And please don't push Qpi/Vtt over 1.2, I leave mine at stock and get 5ghz with 1.39 in bios (droop to 1.38) on a UD3R B3.
Good luck.
  #36 (permalink)
Old March 30, 2011, 02:34 PM
Alpine's Avatar
Hi Chickenman, thanks for thoses answers.
Main system
Server system
  #37 (permalink)
Old March 30, 2011, 03:16 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Exactly what he said.
1) there is nothing wrong with the board 2) Dont use 1.4v VTT, max 1.2v. 3) Your chip is probably maxed
SB is really a joke to OC. Increase multi, increase vcore, test for stability, win. You only need PLL if OCing BCLK. You only need VTT if you are running very high mem clocks. And you dont need to stress test for 20 hours, you are only going to degrade your chip doing that. Run prime for an hour and try some 3d apps and chances are you are fine. GL
Good luck.
  #38 (permalink)
Old April 3, 2011, 07:18 PM
Hey Eldonko, What do you mean degrade your chip? How will the chip degrade if you run a stress test for 20 hours relative to 1 hour? I'm not saying you are wrong, I just want to know where this is coming from.
  #39 (permalink)
Old April 4, 2011, 09:33 AM
I'd like to think about it like a car, if you run the hell outta it for 20 hours good chance something can go wrong. Think of a CPU the same way. Your putting a lot of stress on that CPU, mobo etc... so a much higher chance of things going wrong or burning out faster.
Comp1 (Mine) : ASUS P9X79 LE, 3960X, 16GB Corsair Vengence 1333, PNY 770 4GB, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : ASUS Sabertooth P67, i7 2700K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, EVGA 660, Corsair 1000HX, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Gigabyte 770, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 120
  #40 (permalink)
Old April 4, 2011, 12:54 PM
Wi-Fuzzy's Avatar
Hmmm....so my folding rig that runs 24/7 @ 4.6 1.37ish volts is gonna die soon?
WIP I7 2600K build... Alpine Case Mods, Worklog & Gallery 17 April 3, 2011 02:32 PM
2600k Overclocking Wi-Fuzzy Overclocking, Tweaking and Benchmarking 16 March 27, 2011 06:09 PM
Questions... i7-2600k vs SR-2 Grampa HardwareCanucks F@H Team 29 March 11, 2011 05:21 AM
2600k benchmark botat29 CPU's and Motherboards 12 January 17, 2011 03:03 PM
Intel i7-2600k Zink HardwareCanucks F@H Team 19 January 7, 2011 01:39 PM
