  #21 (permalink)
Old March 29, 2011, 07:35 PM
Alpine's Avatar
As you can see on Easytune.... I change the QPI and on CPU_Z you the vcore is changing.. its the same thing in the bios...
Ill change the Vcore to 1.3 and QPI take the 1.3 value.
if i change the QPI at 1.2 value the Vcore change 1.2
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
  #22 (permalink)
Old March 29, 2011, 07:41 PM
Alpine's Avatar
Ill done a new vid in few mins...
take a look ... On EASYTUNE I CHANGE THE QPI VOLTAGE and the VCORE on CPUZ will change...QPI is not Vcore...... understand ??! (wish i can explain better in english)
Main system
Server system
  #23 (permalink)
Old March 29, 2011, 07:43 PM
Oh I missed the QPI thing..
Well once again proving my point that SOFTWARE = BAD
  #24 (permalink)
Old March 29, 2011, 07:44 PM
G777's Avatar
Yeah, there's certainly terribly wrong with the software that's for sure. The settings you were at previously were set in the actual bios though right?
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
  #25 (permalink)
Old March 29, 2011, 07:49 PM
Alpine's Avatar
this is the same in the bios. When i play with the Vcore in fact it change the QPI. and when i play with the QPI the Vcore change
Main system
Server system
  #26 (permalink)
Old March 29, 2011, 07:51 PM
Alpine's Avatar
I know its bad with software, this is just as a demo. This problem is the same with the bios..
Main system
Server system
  #27 (permalink)
Old March 29, 2011, 07:52 PM
There is no way that if you set the QPI in the bios it'll change the vcore voltage and if it does then either that board or bios is shot.
  #28 (permalink)
Old March 29, 2011, 07:55 PM
G777's Avatar
Try flashing to newer/different bios?
Team Thread
  #29 (permalink)
Old March 29, 2011, 08:06 PM
Alpine's Avatar
if i remember right, they have no other bios for this board at this moment.
Main system
Server system
  #30 (permalink)
Old March 29, 2011, 08:14 PM
G777's Avatar
Ah, Asus has had ongoing bios updates for their P67 lineup since release.
Seems to me the boards defective as is... I mean you paid for an unlocked chip, an overclockable motherboard, and it doesn't work!
Team Thread
WIP I7 2600K build... Alpine Case Mods, Worklog & Gallery 17 April 3, 2011 02:32 PM
2600k Overclocking Wi-Fuzzy Overclocking, Tweaking and Benchmarking 16 March 27, 2011 06:09 PM
Questions... i7-2600k vs SR-2 Grampa HardwareCanucks F@H Team 29 March 11, 2011 05:21 AM
2600k benchmark botat29 CPU's and Motherboards 12 January 17, 2011 03:03 PM
Intel i7-2600k Zink HardwareCanucks F@H Team 19 January 7, 2011 01:39 PM
