Old January 21, 2008, 04:39 PM
vintank's Avatar
Level up: 1% Level up: 1% Level up: 1%
Level: 8 - 179 points to level up
Smile First Successful Overclock
Well my new system is built, DFI Lanparty DK P35-T2RS, 2 x 1024 crucial ballistix ram PC2-8500, eVGA 8800gts 512mb, E6750 with an auzentech x-meridian sound card, all in my Antec 900
Was able to get the E6750 up to 3.6ghz which I am happy with so far and the timings of the ram are at 4-4-4-12 2t with a CPU Core Voltage at roughly 1.38 - 1.420 (or something similar)
Idle temps range from 30C-35C and load temps range from 54C-57C when running Orthos with small FFT's
going to read up some more on raising the ram up, is being at a different ratio than 1:1 good or is it best to stay at that ratio?
the cpu heatsink is the thermalright Ultra 120a with a Noctua fan in the push position, the heatsink is horizontal would it be better in the vertical position or should I just keep it how it is?
aslo does it benefit changing other ram options or best to keep all those at auto have a ton of options in the bios for this DFI Board,
I will post pictures as soon as I take some (is there an easy way to take a screen capture? (never taken any)
FPO/Batch# 3739A930
Packed on 11/07/07
oh and how the heck do you tweak Vista Ultimate 64bit
Old January 21, 2008, 04:45 PM
Push printscreen to take a screencapture of the entire screen to the clipboard, then paste into your favourite image editing app.
Or Vista includes a screenshot tool that can take screenshots of specific areas, including single windows.
Vista doesn't have much that needs to be tweaked for performance, see this guide.
Old January 21, 2008, 04:50 PM
vintank's Avatar
thanks Mars once I am at my computer I will check out those links, unfortunately sitting at our laptop right now as my daughter is watching The Backyardigans and the wife is at work so I am stuck out here till she is in bed hehehe,
are those temps okay?
Old January 21, 2008, 06:20 PM
3.0charlie's Avatar
Temps look fine, it's time to play with the settings. can you lower the VCore, and still be stable? It would give you more headroom temp-wise, and you could increase the OC some more.
Congratz on your first oc!
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old January 21, 2008, 07:33 PM
vintank's Avatar
thank you 3.0 Charlie I am in the process of tweaking the Vcore will let ya know how it goes
Old January 21, 2008, 08:20 PM
sswilson's Avatar
Super Moderator
Tweaking memory settings outside of the auto settings can have a huge impact on performance. Best to get your cpu OC down and stable first though and then set aside a weekend to tweak the memory settings (it can be mind numbing.... :) ).
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
Old January 21, 2008, 08:28 PM
vintank's Avatar
Thanks sswilson noticing that a lot. Well it looks like the E6750 needs to be at 1.424 VCore as it drops to 1.408 with VDroop when the cpu is underload, anything below that gives me a hardware failure in Orthos after 9secs to 2mins.
Ram right now is still running at 4-4-4-12 2t with its voltage at 1.975 or something like that. so looks like I have a stable CPU overclock, will run orthos again tomorrow while I am at school to see how it goes again, hehe I like double and triple checking at times.
Should I increase the ratio at all to get the speeds higher for ram, to start that is, or is the 1:1 ratio best?
Old January 21, 2008, 08:53 PM
Level up: 8% Level up: 8% Level up: 8%
Level: 14 - 540 points to level up
Congratulations on your first overclock!
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old January 21, 2008, 09:42 PM
vintank's Avatar
thank you tzetsin
DFI Lanparty DK P35-T2RS, E6750,
Crucial Ballistix PC2-8500 4 x 1024
Thermalright Ultra 120a with Noctua fan
eVGA 8800GTS 512MB
Auzentech X-Meridian
Antec 900, with 5 Noctua Fans
1.650 terabytes worth of HDDs
GameXstream 600w PSU
Old January 22, 2008, 10:55 AM
vintank's Avatar
well ran orthos again and today the temps are getting up to 62C - 63C beginning to think that the heatsink isn't seated properly and I know the thermalright thermal paste that came with the heatsink isn't the greatest will take off the thermalright ultra 120a and clean them both up nice and good and reapply some thermal paste. will keep you updated as been reading some reviews about these processors and most are able to hit 3.6ghz with stock voltage maybe its the motherboard I decided on honestly I don't know let me know what you guys think please and thank you
even when set to stock everything the temps are 34-36c at idle which seem high to me going to put the stock heatsink on and see what the temps are like
eVGA 8800GTS 512MB
Problems with overclock FritzGuy Overclocking, Tweaking and Benchmarking 6 December 10, 2007 07:14 PM
Help me Overclock my Firestix. Dethredic Overclocking, Tweaking and Benchmarking 11 November 9, 2007 10:15 AM
8800 GTS 320 MB overclock belgolas Video Cards 2 September 21, 2007 06:52 PM
24/7 Overclock? bushwickbill Overclocking, Tweaking and Benchmarking 5 August 25, 2007 05:32 PM
