Old January 22, 2008, 01:33 PM
I have the same CPU/Heatsink/RAM as you do and my idle temps are 34C or so, so it's pretty normal. As for the RAM, I've found that more Mhz is almost always better than tighter timings, unless you're shaving it really close. I run my FSB at 479, so at 1:1 my ram runs at 958Mhz, 4-4-4-12.
I pushed it to 1200Mhz (4:5 FSB ratio), but I had to loosen the timings at lot (6-5-5-6-18 I think, I'd have to check) and Everest gives me *much* better RAM performance than the tighter timings at 1:1.
Intel Core 2 Duo 6750 @ 3.8Ghz
Asus P5K-E/WI-FI
Thermalright Ultra 120 Extreme Heatsink
2x1GB Crucial Ballistix PC2-8500 @ 1200Mhz
Galaxy Geforce 8800 GT 512MB
Antec P182 Case
Old January 22, 2008, 02:22 PM
vintank's Avatar
Level up: 1% Level up: 1% Level up: 1%
Level: 8 - 179 points to level up
okay cool thanks Spblue I took apart the cpu and heatsink cleaned them up and reapplied the thermal paste, all to switch the way the heatsink position, now I have it vertical instead of horizontal with the fan in the front pushing air through it. will see how it goes what motherboard are you running?
DFI Lanparty DK P35-T2RS, E6750,
Crucial Ballistix PC2-8500 4 x 1024
Thermalright Ultra 120a with Noctua fan
eVGA 8800GTS 512MB
Auzentech X-Meridian
Antec 900, with 5 Noctua Fans
1.650 terabytes worth of HDDs
GameXstream 600w PSU
Old January 22, 2008, 02:58 PM
As my sig says, it's an Asus P5K-E/WI-FI. It's basically a rebranded Deluxe (same PCB), except there's only one network adapter (in addition to the wireless one) and I think a missing heatsink on the southbridge. Really satisfied with it so far.
Your temps might be a little bit high I guess, they're a bit higher than mine at load. I get 60C at full load, maybe 61C if the room's warm. CPU is running at 3.8Ghz @ 1.45v. I do have 2 fans on my heatsink in push/pull config, I'm not sure if that might be the difference.
Asus P5K-E/WI-FI
Antec P182 Case
Old January 24, 2008, 07:54 PM
vintank's Avatar
Got my overclock back up to 3.6ghz on air ram timings are 5-5-5-15 2t 2.2V, Core Voltage is 1.424, bumped up Northbridge a little and am currently running orthos temps are 60C on load and 34C on idle
eVGA 8800GTS 512MB
Old January 25, 2008, 11:56 AM
That matches exactly my temps. Congrats on your OC.
Asus P5K-E/WI-FI
Antec P182 Case
Old January 25, 2008, 12:09 PM
vintank's Avatar
thanks Spblue, now pricing out my other computer to go with the E8400 not sure what motherboard to get though, going to use the same ram, heatsink and fans but different case, power supply (probably an OCZ again just a bigger one) same video card and a couple 500gb hdd's, eventually going to get a Mountain Mods Duality and water cool both systems but that might be awhile haha, unless I find a tree that has money growing on it
eVGA 8800GTS 512MB
Problems with overclock FritzGuy Overclocking, Tweaking and Benchmarking 6 December 10, 2007 07:14 PM
Help me Overclock my Firestix. Dethredic Overclocking, Tweaking and Benchmarking 11 November 9, 2007 10:15 AM
8800 GTS 320 MB overclock belgolas Video Cards 2 September 21, 2007 06:52 PM
24/7 Overclock? bushwickbill Overclocking, Tweaking and Benchmarking 5 August 25, 2007 05:32 PM
