Old March 17, 2011, 09:37 PM
Ging9's Avatar
Default Asus AI and CPUID
Just assembled my new SB tower including and Asus P8P67 Deluxe and 2500K. Thought I'd try my hand at using the AI software. I fired it up and it gave me a 31% overclock to roughly 4.5 GHZ...I thought, "great"...that was easy.
SOOOO....I download the latest CPUID to check things out and this is what I get when I run it...
[IMG]file:///C:/Users/Peter/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/Peter/AppData/Local/Temp/moz-screenshot-1.png[/IMG]
I don't understand why the CPU frequency reads so low along with the multiplier being only 16. Name:  CPUID capture.PNG
Asus P8P67 Deluxe, i5 2500K, MSI 560 GTX Ti, Corsair 600T, 4X2 GB Kingston 1600, Corsair H60, PC P&C 750.
Old March 17, 2011, 09:39 PM
Old March 17, 2011, 09:44 PM
Originally Posted by enaberif View Post
you got power saving thingie enabled, if its stable no worries.
drop prime or linx on it and see if its cool.
Old March 17, 2011, 10:01 PM
Ging9's Avatar
Power saving thingie? Ok, so how do I calculate my actual clock speed? Sorry for the dumb question, but I don't understand why it's reading so low.
Old March 17, 2011, 10:26 PM
ZZLEE's Avatar
Run somthing CPU hungry check it agian while it is running. benchmark.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 18, 2011, 03:13 AM
Newer processors will choke back the speed and multiplier in order to save energy while it is sitting idle. They are Al Gore approved. Run something that requires the computer to work while leaving CPUID open and it should jump right back up to your actual frequency and multiplier.
Old March 18, 2011, 06:42 AM
Ging9's Avatar
Thanks for the help! Ran Prime 95 64 bit and CPUID shows 4326 mhz, 42 multiplier and 1.3 volts....
[FS] "Its gotta go"....all sold thanks!! stoanee Buy/Sell & Trade 12 November 29, 2012 04:19 PM
BIOS & CPUID show different CPU Frequency Rasparthe Overclocking, Tweaking and Benchmarking 0 January 9, 2011 10:15 AM
Installing SSD & W7 (Using Asus Recovery Disc) On Asus G51J Notebooks rjbarker Mobile Computing 0 February 19, 2010 11:36 AM
CPUID Hardware Monitor - temps question somecanadianguy Overclocking, Tweaking and Benchmarking 8 June 16, 2009 05:11 PM
Q about real temp by intel and CPUID monitor contractk Overclocking, Tweaking and Benchmarking 8 March 29, 2008 09:51 AM
