Old January 19, 2008, 12:47 PM
Default NVFlash for Vista x64 help
Anyone know where I can get a working Nvflash that will work on Vista x64. I need hardcore the change of fan speed
Old January 19, 2008, 02:32 PM
lowfat's Avatar
Level up: 65% Level up: 65% Level up: 65%
Level: 14 - 205 points to level up
NVFlash is a DOS utility. You'll never get it to work while in Windows. Also if you are trying to change the fan speed of a Galaxy 8800GT (rev3), sorry it isn't going to happen. I tried 4 different bioses including a few bioses for the 8800GTS...
Old January 30, 2008, 09:21 AM
BFG 8800gts 512MB the default fanspeed is way too low it overheats too much
Old January 30, 2008, 06:39 PM
I'd apply some nicer TIM on the heatsink in this case.
