-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   Comments on my OC (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/41477-comments-my-oc.html)
sakage.shinga March 9, 2011 04:41 PM
Comments on my OC
Hi guys,
So I've had my rig mildly overclocked for a few weeks now, and everything is stable as far as I can tell, but I'd like to get people with much more experience than I have to take a quick look at my BIOS settings to confirm that I've not made any big no-no's.
AI Overclock Tuner Mode : Manual
CPU Ratio Setting : 21
Intel(R) SpeedStep(TM) Tech : [Disabled]
Xtreme Phase Full Power Mode : [Enabled]
BCLK Frequency : 160
PCIE Frequency : 100
DRAM Frequency : 1600MHz
QPI Frequency : [Auto]
CPU Voltage Mode : [Manual]
Load Line Calibration : [Enabled]
CPU Spread Spectrum : [Disabled]
PCIE Spread Spectrum : [Disabled]
CPU Configuration
C1E Support : [Disabled]
A20M : [Disabled]
Intel SpeedStep Tech : [Disabled]
Intel C-STATE Tech : [Disabled]
This is pretty much all I've touched in my BOIS. Thoughts? Comments?
Thanks!
_dangtx_ March 9, 2011 04:55 PM
you got to leave the cpu protection on, increase your bus, drop ram to 1333 or whatever till you find a cpu speed stable,
drop qpi if you cant get it stable. start with linx 5-15min, then if ok, prime it and loop 3dmark.
Wi-Fuzzy March 10, 2011 07:34 PM
you should have more room left. Intels turbo clocking for this core is 3.2 ghz.
MegaBUD March 11, 2011 12:39 AM
You should be able to push it to 3.6-3.8 with leaving everything on auto...
I can do 21x180 with 1.25v.
But my rams run a little slower... 1440 instead of 1600, which give me a chance to reduce the timing.
sakage.shinga March 17, 2011 08:15 PM
Thanks guys. I'm happy with ~3.33GHz for now, might try bumping it to 3.8 in the near future once I'm done playing Dragon Age Origins, which doesn't handle OC'd rigs very well.
