Originally Posted by MaDDN3ss First off, are you going right to 750+ or going up incrementally? Try going up at 5 mhz at a time.
It may not be your GPU but your memory. I had a 7800GTX that would OC on the core beautifully but the memory had very little headroom. |
i'm going up little by little. if i do memory only i can do 1080 no problem its the core giving me issues i think... But i heard that the 8800GTS 512mb should auto ajust the fan speeds. Mine isn't I have to set it to what I want it at
