  #31 (permalink)
Old January 21, 2008, 03:18 PM
1Tanker's Avatar
Level up: 27% Level up: 27% Level up: 27%
Level: 13 - 357 points to level up
Originally Posted by donimo View Post
So VNB means +0.3?
FSB and PCI max?
And is that Vcore SET, or ACTUAL?
PCIe setting can help stabilize things. At the very least set it to 100(not Auto)...but 101 can help. On my soon-to-be replaced ASRock 775 Dual VSTA, i set PCIe to 117MHz, and it allows me to top out the FSB at 297(not bad for this chipset). Luckily..i can get away with 117 no problems, because i'm still using an AGP graphics card. Assuming your Ballistix use D9GMH or D9GKX IC's, you should be okay with 2.25-2.3v(with a fan on then) and a bit higher for benching/screenshots... but not long-term(consider that OCZ's D9 DIMM's are rated at up to 2.3v-2.4v + 5%{EVP}). ***As usual...do so at your own risk.***
  #32 (permalink)
Old January 21, 2008, 04:47 PM
vintank's Avatar
Level up: 1% Level up: 1% Level up: 1%
Level: 8 - 179 points to level up
I ran into a similar problem initially with my E6750 couldn't get it past the 3.4 but once I actually figured out how to increase my CPU Core voltage it is now 12 hours stable with orthos at 3.6ghz
  #33 (permalink)
Old January 21, 2008, 05:24 PM
3.0charlie's Avatar
Agreed on Not Auto; I always set it to 100MHz. It's from the old AGP days, when you had to lock the PCI freq to 66MHz... I set it to 100MHz and forget about it!
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
  #34 (permalink)
Old January 21, 2008, 10:55 PM
Level up: 9% Level up: 9% Level up: 9%
Level: 13 - 441 points to level up
did that, but I agree it needs to be said. They labeled it wrong, should be "unlinked" or "linked"
My komPuter - Mobo P35-DS3L rev2 CPU e6750@3.2GHz CPU Cooler: TRUE w/2xNF-SP12's RAM:2x1GB Ballistix@800 GPU:x1950pro GPU cooler :AC Accelero S1 Case: Antec 900 PS: Antec SP-500 Monitor:Samsung 931c
donimo's first "just for fun" rig donimo Worklog 21 January 12, 2008 11:30 PM
Comment thread for the "Asrock 4CoreDual-VSTA" review sswilson CPU's and Motherboards 16 December 18, 2007 09:04 PM
"Reviewer Tryouts:" Logitech Cordless Desktop LX710 Review Scratch Member Reviews 9 November 22, 2007 10:17 PM
another "New System" thread Unklmo CPU's and Motherboards 20 June 15, 2007 08:39 PM
