posts just fine at 4.0 (500x8), bu windows BSOD's tried up to 1.450v and stopped bothering I would love to try a different PS, the Vcore is always0.05 less than set, plus a big droop on load. 1.45 Vset is 1.41 Vactual, and 1.38 Vload I thought Vcore was regulated b the mobo, but I guess PS could affect it (shouldn't)
__________________ My komPuter - Mobo P35-DS3L rev2 CPU e6750@3.2GHz CPU Cooler: TRUE w/2xNF-SP12's RAM:2x1GB Ballistix@800 GPU:x1950pro GPU cooler :AC Accelero S1 Case: Antec 900 PS: Antec SP-500 Monitor:Samsung 931c |
Have you raised the NB volts? And I would try 1.475V VCore...
__________________ Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182 HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B |
That vdroop your talking about is probably not your PSU....I suggest checking online if you can find something like a pencil mod for your motherboard. Try reading this thread. Good luck!
__________________ Last edited by Prof. Dr. Silver; January 18, 2008 at 02:46 PM. Reason: Edited the link |
We are far from being Electrical Engineers and in no way will I modify my board.... if it droops, then too bad.
I never really thought it was my PS, its job has VERY little to do with Vcore, if it was spastically unstable with huge ripple etc I could say maybe, but supplying enough juice for a cpu that takes under 2Vcore is a cake walk, its the mobo VRM that deals with that. Now having said that, I do think that Vdroop/offset is important, especially after seeng that AA article, but I think it is a tad excessive. How do I know how much is too much? Should I be going off settings or actual voltages, idle or load values? I know I should not push it past the high 1.4's but I could set it at 1.58v and get a Vload of under 1.48... argh... I will see how 3.4 at stock Vcore goes, and go for 4.0 again tonight, it posts perfectly so I have hope :)
| Quote:
You cant get a specific value out of it and the value changes over time. I feel a BIOS revision could help, but that aint up to me...
| Quote:
Sometimes we have to take risks... and be brave/stupid(actually a mix of both). ![]() |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| donimo's first "just for fun" rig | donimo | Worklog | 21 | January 12, 2008 11:30 PM |
| Comment thread for the "Asrock 4CoreDual-VSTA" review | sswilson | CPU's and Motherboards | 16 | December 18, 2007 09:04 PM |
| "Reviewer Tryouts:" Logitech Cordless Desktop LX710 Review | Scratch | Member Reviews | 9 | November 22, 2007 10:17 PM |
| another "New System" thread | Unklmo | CPU's and Motherboards | 20 | June 15, 2007 08:39 PM |
