Old January 19, 2008, 08:13 AM
For RAM testing I started with 2 Instances of Super Pi - 32M. It would take about 25 minutes, and it passed fine.
After your post I finally tried MemTest, The comp fell on its face soon after starting. Looks like I have more tinkering to do with the ram, which REALLY is a good thing, since I want 100% Stability over a larger OC
When I put the ram timing stock and tried Further OC'ing the CPU, and have been able to do so.
I trimmed the voltage down to 1.4 to see where I can get to.
Thanks for the advice
Intel E6600 (Stock 4 Now) w. Ultra 120 Extreme
Asus P5N-E
Muskin HP2-5300
2X1GB DDR2 @ 836, 5-3-3-3
MSI NX7800GT (480mhz & 256MB @1202mhz)
Samsung SyncMaster 225BW (22" Wide - 5MS)
Western Digital 74GB Raptor X 2 (Raid 0)
Seagate 750GB - SATA 2 - 7200.10
Apex 600W PSU
Audigy 4 Pro, Yamaha HTR, Cerwin Vega Speakers (5.1)
Logitech diNovo Edge and MX Revolution
Old January 19, 2008, 09:53 AM
3.0charlie's Avatar
So your Ram is stable at that speed, but the timings are unstable. Before changing anything, I would loosen the timings in order to have Memtest stable. Once that's done then I would concentrate on the CPU.
Good job.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old January 19, 2008, 03:59 PM
I forgot to mention in my earlier reply that I unlinked the memory and cpu timings when I started OC'ing the ram.
I was able to run the ram @ 836 MHz, with timings @ 5-3-3-3, Memtest stable after over an hour.
I am going to try and stress test my cpu and ram with Ortho's. Is there another program I can try to use to Stress test my ram? I was my comp to be 110% Stable @ my final OC
*EDIT*
I just looked at CPU-Z moments after posting. It shows my memory timings as I have them set, but the Bank Cycle Timer (tRC) is 25. tRC is currently set to auto. Is 25 high or does it just seem this way?
What is a good program to use for memory benchmarking?
Thanks again for all the help :)
Asus P5N-E
Muskin HP2-5300
Apex 600W PSU
e6600 Over clocking limit? mattydies Overclocking, Tweaking and Benchmarking 12 December 21, 2007 01:03 PM
