Old February 21, 2011, 03:15 AM
Default phenom II 955 4ghz under 1.35v
Got my hands on a new 955 through a trade, threw it into my biostar 890fxe
and got down to business. My mobo set the stock voltage to 1.3v and i locked everything down.
Just pushed the multi alone and sucessfully booted to windows with a 20x multi, I didnt try to go any further. Prime of course failed, so i increased vcore to 1.32, booted and ran small fft's. It completed one round successfully (surprised) and then I tried to run the blend test, it of course failed. Then I increased the NB freq to 2600 @1.125v and the HT link to 2200. Core voltage was rock stable until I increased the nb voltage and now it seems to droop to 1.31/1.308. Now running prime blend for over an hour now and it seems to be holding together so far.
Crossing my fingers that this is stable, from my reading this is pretty good for these chips at under 1.45v.
Max temps on all cores hasnt exceeded 50c with a 212+ push/pull and fans not exceeding 1100 rpm
NB is pretty warm maxing at 60c, Hwmonitor is reporting my cpu 111w of power.
Crossing my fingers that i can get this stable w/o increasing vcore, from my understanding this is pretty good for these chips at under 1.45v
So far this is haw it stands. sorry about the low res, i cant figure out how to get an hd screenshot posted.
http://i1226.photobucket.com/albums/...Hzattempt1.jpg
Old February 21, 2011, 10:24 AM
gingerbee's Avatar
thats great for that voltage wow nice chip
Old March 28, 2011, 08:03 AM
francisw19's Avatar
Yeah that's great indeed! I needed 1.45V under load to get my PhenomII to 4.0GHz. Nice to see you did it with just a small bump from stock volts.
Old March 28, 2011, 08:18 AM
that is quite the feat. very nice. i wonder what that chip could do under phase or such!
edit : how can i miss these things on here
Old March 28, 2011, 10:25 AM
that is pretty good, I have a 955 at 200x20 stable at 1.37v. its also a c3, and from what I hear they are much better clockers than the older revisions!
Old April 16, 2011, 11:15 AM
Final 24/7 OC , 13h 26m prime blend, 2.5 hrs small fft and bc2 stable.
4.08ghz 240*17 1.35vcore
ht 2160 nb 2160
ram @ 1280mhz 8-8-8-20 1.55v
cant remeber what the northbridge is at, was only a small bump in voltage i think around 1.1375
max temp on the cores was 58c on a 212+, the temps are pushing it though and im thinking of getting a d14 and seeing if i can go further.
Old May 4, 2011, 01:36 PM
What is the stock voltage of the 955 c3 ?
Old June 16, 2011, 05:50 AM
I think it's close to 1.35v. But if you have it set to down clock when it's not needed (name of that feature?) it drops to .95ish.
Old September 3, 2011, 10:06 AM
I would prime for at least 48 hours, I have had chips fail prime95 about 3 days in sometimes
Old September 6, 2011, 03:45 PM
Are you overclocking anything else like your video card or PCIe bus?
[WTB] * anabioz Buy/Sell & Trade 0 October 11, 2010 08:36 PM
phenom II 955 speedfan help rickbmb CPU's and Motherboards 3 September 9, 2010 05:04 PM
Phenom II 955 BE Pukka Overclocking, Tweaking and Benchmarking 4 December 16, 2009 11:41 AM
I5 750 vs. Phenom II 955 bumfloss New Builds 13 December 11, 2009 01:15 PM
phenom ii x4 955 temp? tranceholic CPU's and Motherboards 7 August 30, 2009 11:53 PM
