Old January 29, 2008, 03:07 PM
BALISTX's Avatar
Level up: 54% Level up: 54% Level up: 54%
Level: 21 - 564 points to level up
My OCZ Plat before wouldn't go past 405.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
BALISTX.com
Old January 29, 2008, 03:36 PM
Level up: 8% Level up: 8% Level up: 8%
Level: 8 - 167 points to level up
first it was the same for me but i found a way to get it to 420mhz but over that no tests passes.
asus p5kc, e6750 with thermalright ultra 120 extreme and antec tricool fan, evga 8800gt superclocked with thermaltake duorb, 2gb of crucial ballistix tracer and 2gb of mushkin hp, 1 seagate barracuda 250gb and 1 seagate barracuda 500gb
Old February 13, 2008, 04:20 PM
can my p5kc be the problem? because i've tried to OC my crucial ballistix with my mushkin to 960mhz (ratio 5:6) and i got errors on memtest86+ than i have tried with my mushkin only and at 960mhz(ratio 5:6) i got errors too(i've put my vram to 2.4 and the timing at 5-5-5-15). Do i need to increase the vcore when i test my ram at higher frequencies with memtest86+. I've been told that the p5kc board is a good board but not a really good one for OC, is it true? is it worth it to buy a new mobo like the gigabyte p35-ds3l and try to get a better oc from my 6750 (3.2ghz on my p5kc)?
Old February 14, 2008, 08:56 AM
Originally Posted by djnocide View Post
i've decided to change for mushkin hp (XP cost a little too much for me right now). Is it a good choice? (ocz reaper or corsair xms2 are my other choices)
My reapers (PC2-6400) run at 4-4-4-12 @ 2.1v, 850mhz without an issue. Any faster and they get really cranky, and my system won't boot when I push much higher than 900mhz. I am pretty disappointed to be honest with you (and I bought them because the reviews I read were so positive as well).
Gigabyte P35-DS3R | E2180 @ 3.4ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 510mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900.
Intel E1xxx & E2xxx OC Thread
Old February 14, 2008, 03:16 PM
i find it weird that 2 set of ram (crucial ballistix tracer and mushkin hp) can go as high as review say (from the mobo and from the ram) so i'm wondering if i'm very unlucky with my ram or the mobo just suck.
Old March 29, 2008, 07:45 AM
Hi, I have the plats rev 2 and haven't tried pushing it past 400 yet. Did you try relaxing the timings and putting the full volts?
Intel E6750 C2D
400x8 (3.2GHz) 32C idle/58C Load 1.31 V stock HSF | Gigabyte DS3R Rev 1 bios F11 | OCZ XTC Rev 2 @4-4-4-15 | Antec Sonata 3 500W | Palit 8800GT driver v.169.21 | WD 500GB | 22" 226BW | Logitech x-540 5.1
Old March 29, 2008, 09:24 AM
vinister's Avatar
Level up: 10% Level up: 10% Level up: 10%
Level: 10 - 252 points to level up
Wow I have 2 x 2gb OCZ platinum, rated at ddr-800 and it does ddr-950 with no problems at all.
djnocide it sounds like you should have spent a bit more $$ on a faster cpu. Nothing wrong with 3.3ghz, its more than enough if you have some good video card(s)
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X4 9850
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870 @ 900/1300, hard-modded
Stuck on my 1st build Mr. Cipher Troubleshooting 9 November 2, 2007 02:36 PM
Need some help , stuck at 2.77 on e6400 bushwickbill Overclocking, Tweaking and Benchmarking 6 July 22, 2007 07:55 PM
