Hi guys, fairly new around here, just decided to drop by and share my results for OC-ing!
I decided to start OC-ing the 970 after I got my job at NCIX for..yeah self explanatory, anyways, everythings stuffed in a 912, reason I chose such a small case is for the extreme negative wind pressure with 3 120MM & only 1 200MM megaflow, it allows my Noctua NH-U12P to breathe a whole ton better, this OC isnt set in stone yet as I'm still only using 2x3GB DDR3-1600MHZ OCZ obsidian ram (got them in HK for 20$ a piece!), I plan to upgrade to more suitable RAM like XMS3's or Dominators.
The OC was intended for the lowest voltage and highest multiplier while working with this set of RAM. I think I achieved that with a 4ghz OC & 1.296VCORE :)
I plan to set a personal record by going at least 4.7GHZ if possible, though I don't want to implode the processor or RAM
