Old January 13, 2008, 05:57 PM
Khronos's Avatar
Default Did I OC Correctly?
I recently overclocked my HD3850, and it was really easy thanks to CCC. Anyway, I have a question. It says my requested clocks are 740MHz/904MHz, but then at the bottom it says the current clocks are 300MHz/829MHz.
Did I OC right?
|AMD 4800+ @ 2.5GHz|
|Gigabyte MA790X-DS4|
|2GB Mushkin HP DDR2 800 @ 4-4-4-12|
|Diamond Viper HD 3850|
|250GB WD Caviar|
|Pioneer 212D|
|OCZ StealthXStream 600W|
|Antec 900|
Old January 13, 2008, 07:33 PM
Prof. Dr. Silver's Avatar
If I remember correctly, it was long ago with CCC....the current clocks shown are 2D clocks....you don't want to overclock those. The only thing that needs to be overclocked are the 3D clocks. And they only start to work once the system shows 3D graphics such as games or benchmarks.
That they did to make sure the card doesn't always run overclocked and therefore gets too hot or even burn-out!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Raid 0 set up correctly? SyrousPL Storage 8 December 4, 2007 03:49 PM
