Old February 12, 2011, 02:22 PM
yup. or hold del at boot, see if recovery pops up.
Old February 12, 2011, 03:39 PM
What are you using to read your voltages? I found OCCT to be way off, (it says I'm at 1.42V vCore), so the only utility I trust is the motherboard's OCing software (for me that's Gigabyte EasyTune, which states 1.260V, which is in line with the 1.255 I set in BIOS).
At 4.2GHz I never broke 56 degrees C in stress tests (Prime95 in-place FFT, Linpack), and that's on a Prolimatech Megahalems + Arctic Silver 5 + Scythe S-Flex fan. See if you can use a lower voltage but with VDroop Control / Load Line Calibration turned on.
Old February 16, 2011, 12:06 PM
SneakySnake's Avatar
I use OCCT on my 2500k as well and don't take into account what it says for voltages and stuff. Apparently it has to be updated for the Sandy chips.
Intel Sandy Bridge High C/P Combo-Core i5-2500K with GIGABYTE P67A-UD3R OC Guide windwithme Member Reviews 5 February 10, 2011 01:38 PM
2500K + P8P67 Pro Overclocking Realityshift Overclocking, Tweaking and Benchmarking 0 January 24, 2011 10:20 AM
No gain from Radeon 4870 + Core i5 2500k folding frontier204 HardwareCanucks F@H Team 3 January 18, 2011 04:56 PM
AKG? Best Coolers for Sandy Bridge 2500K-2600K OC Delavan Air Cooling 12 January 10, 2011 03:33 PM
