Old January 12, 2008, 07:18 PM
Default temp. monitoring utilities and e2180
hi
so i've overclocked my e2180 to 3.0ghz on 1.3000V (stock) on a Gigabyte DS3L rev 2.0 with a Scythe Ninja cooler. Everything seems stable, although I havent ran a long stress test yet. I was wondering what is the most accurate program to measure cpu temperatures? it seems that people trust Core Temp, but coretemp consistently reports temperatures ~15 C higher than every other program i've tried (Intel TAT, PC Wizard '08, Sandra, Speedfan, BIOS/Easytune). At full load (orthos) after about 10-15 minutes my overclocked temperatures reach 60-65C according to Coretemp (higher if TAT is used to stress), in the other programs they wont go above 50. At first I thought that this was due to the heat sink mounting mechanism (no backplate, so the contact between base and cpu could be not strong enough) but i ruled that out by checking the temperatures when the case was on its side and applying pressure to the cooler. so now I have my doubts about Coretemp. Should I trust it? Or can I go farther with my overclock?
Thanks
Old January 12, 2008, 07:56 PM
donimo's Avatar
I would like to know too, same board, same cpu.
Oh and I hate you because mine wont even go past 2.4ghz on stock voltage (which is 1.325 btw, so you are getting that off an undervolt, argh)
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old January 12, 2008, 08:00 PM
3.0charlie's Avatar
Do trust Core Temp. And nothing else. Run SuperPi 1M, dual 32M and Orthos Blend for 12 hours for stability. Check those temps - 65C is the max I would allow under Air.
Old January 12, 2008, 08:03 PM
donimo's Avatar
Im salty about my 2180
mine is at 62*C on 1.41 volts at 2.85ghz so yours may be a bit toasty for undervolting....
Old January 12, 2008, 08:27 PM
charlie do you think its a heatsink mounting issue then? I mean ninja is pretty big and should be able to handle stock voltages better than this...
Old January 12, 2008, 10:21 PM
3.0charlie's Avatar
I think it's just the fact that it's running at 3.0GHz. Is it stable - have you tested the chip? If so, I would say you have a Golden Chip...
Old January 12, 2008, 10:32 PM
JD JD is offline
Make sure it is the latest CoreTemp:
Get it here: Core Temp
It could be that you have an old version which doesn't report the temperatures properly. If you have the latest, then trust it.
3.0GHz on stock voltage is pretty nice IMO, although those temperatures are a bit high (assuming it's right).
Maybe you could improve your case airflow? Perhaps post some pictures of your system.
Old January 12, 2008, 11:23 PM
Cheator's Avatar
If you have an M0 stepping, ensure that you are using CoreTemp 0.96. There is also HWMonitor on cpuid.com which I love. Its my new tool of choice, though coretemp still kicks.
Optimus: Antec P180, Asus P5Q-E, E8400, 4 GB RAM, Asus 4850, Seagate 320gb, Antec TC II
Teletraan I: Asus P5K-E/WIFI, E4500, 2 GB RAM, ATI 3450, Sapphire Theatrix, 2.25TB storage, Antec SP2 400w
Galvatron: Asus M2NPV-VM, 3800+ X2, 2GB RAM, NV8500GT, Seasonic 500w
Tracks: Acer AS5920, C2D 2.1ghz 45nm, 3GB DDR2, NV8600m GT, 250gb hdd
Hound: Gigabyte GA-MA74GM-S, AMD 4400+ X2, 1 GB RAM, 2900XT, 500w Seasonic
My Heatware!
| Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old January 13, 2008, 02:00 AM
donimo's Avatar
all e2180's are M0 stepping.
but obviously some are "extra wicked" M0 stepping
Old January 13, 2008, 02:12 AM
thanks for the replies guys. here's a pic of my case, I think the air flow is pretty good, the top exaust is basically right over the heatsink so its almost as if I have the Ninja with push/pull fan setup.
So even at stock, 2000mhz and idle, CT reports 44/40C CPU temperatures. HW Monitor reports 29/25. CT temperatures are kinda warm for idle methinks, especially for such a big cooler, so I think its either a mounting issue or Coretemp is reporting incorrectly, because every other program that also supposedly reads the on-die digital sensors (TAT, HW monitor) reports much lower temps. May be I need to switch in the stock intel sink and see how it does in comparison?
Overclocking e2180 experiences Mr. Cipher Overclocking, Tweaking and Benchmarking 16 March 19, 2008 06:36 AM
BALISTX Intel E2180 Overclock BALISTX Overclocking, Tweaking and Benchmarking 28 February 24, 2008 11:39 PM
donimo's e2180 o/c log donimo Overclocking, Tweaking and Benchmarking 19 January 13, 2008 03:09 PM
PC Monitoring chibi_man O/S's, Drivers & General Software 5 November 25, 2007 10:46 AM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
