Old February 9, 2011, 11:08 AM
that i do not know.
lets say your psu is mighty fine, but then again i dont know how much the boards components can take.
from what i see its got 3 phases. not bad but not very good either. but then again this board was made for value chips
something like dual cores with lower power figures.
Old February 9, 2011, 11:13 AM
Oh.. thanks for answering Dan!!!
Lets say I want to OC to 2.8, 3.0Ghz at the most. From what I have read this sounds like a modest enough raise for this kind of MB. How would I go about it???
Old February 9, 2011, 11:32 AM
I can show you how to do it but please don't blame me if you kill your motherboard... That board does not have a beefy enough power phase design to do this reliably... you would probably be fine overclocking a low wattage dual core but doing this with a 95 watt quad is asking for trouble... The performance increase in going from 2.66 to 2.8 or 2.9 would not be that great anyway... not worth it in my opinion...
Old February 9, 2011, 11:44 AM
Show me the way!!!
I think a raise from 2.66 to 2.8 is as far as I would take it. What do I do?
Old February 9, 2011, 12:05 PM
Enter the bios by pressing del or F1 after rebooting... under advanced>cpu configuration... set overclock mode to cpu pci-e asyth, set pci-e frequency to 100, disable spread spectrum, disable intel speedsted technology... now raise the cpu frequency say 5-10 mhz at a time and reboot till you reach your desired O.C. Check for stability using a program like prime95. You should also lower your ram speed to remove this from the equation... Advanced>chipset configuration>dram frequency... set this below your rams rated speed... you can raise it back up later when you determine that your cpu frequency is stable or your vrm's explode
Good luck!
Old February 9, 2011, 12:18 PM
Good luck!
Awesome!!! Thanks man!!
The thing is I am have a new set of gaming memory DIMMS. I recently purchased 8 (2x 4GB)GBs of Patriot gaming memory. They have enhanced latency specs( 5-5-5-12) and need a voltage of 1.9V. Is there any thing I might have to do differently when using these babies?????
Old February 9, 2011, 12:28 PM
Your board should auto detect the modules and set the required parameters... You can also set the timings and voltage manually if it doesn't do this properly... for timings go to advanced>chipset configuration>flexibility options (enable this) for voltage go to dram voltage on the same screen and enter desired voltage...
Old February 9, 2011, 05:54 PM
Thanks for your assist Boggs
I do have one final question. My MB manual says that in order to OC the FSB to 1600 I have to adjust the jumper settings. Is that something I need to do for this kind of mild overclocking or can I skip it
Thank you once again
  #19 (permalink)
Old February 9, 2011, 08:02 PM
well, try without touching the jumpers and see how well it plays.
i dont have much experience with that board+oc'ing :)
  #20 (permalink)
Old February 9, 2011, 08:04 PM
Nah... I don't think that is necessary. Just up the cpu frequency to where you want it or where it is stable... Moving the jumper probably locks the board at 400 fsb...
[FS] Laptop Ram: 2 gbs DDR3 & 1 gb DDR2 quikgp Buy/Sell & Trade 7 May 5, 2009 05:08 AM
[FS] Asrock G31M-S summerlite55 Buy/Sell & Trade 2 April 19, 2009 11:46 AM
Asrock G31M-S overclock anyone else? summerlite55 Overclocking, Tweaking and Benchmarking 23 April 16, 2009 06:56 PM
Get Patriot Ram mailaw RAM 5 July 18, 2007 08:26 PM
Using AsRock Untied Overclocking with an Intel SP79K ? lamimartin Overclocking, Tweaking and Benchmarking 0 May 4, 2007 08:28 AM
