<hmm if someone can put a bad idea icon beside my post title like a broken lightbulb or something I'd appreciate it
Hi all,
I'm in that strange "let's kill things" mood so I'm trying to trigger the Cougar Point SATA2 issue. Call it a suicide run with a motherboard or something...
Anyway, here's the setup, running on my main:
Core i5 2500k OC 4.2 GHz running F@H SMP
Radeon 4870 running F@H GPU (clocked at stock 4870 speeds)
2x4GB G-Skill Ripjaws DDR1333 9-9-9-24 (stock)
Gigabyte P67A-UD3P
Connected to SATA3 ports 0 and 1:
Kingston SSDNow V Series 128 GB (running in SATA2 mode)
WD Caviar Black 1 TB (running in SATA3 mode)
Connected to SATA2 ports 2 and 3:
Seagate 7200.10 360 GB
Seagate 7200.10 320 GB
Connected to SATA2 port 4 and5:
SATA -> ESATA -> Enclosure -> Seagate Momentus 7200.2 (mobile 120GB)
Cheap LG DVD burner
I plan to stress the old Seagates in a non-organized fashion over a longer period of time to see what happens. As for now, pictures can explain what's happening:
Initial Benchmarks:
EDIT: Adding another HDD into the mix, this time through eSATA enclosure.
Stress #1
I'll check again with the benchies in a 1-3 days if the heavy I/O actually affected performance.
