Old February 3, 2011, 03:30 PM
Default Day ~2...
Both drives passed a long DST and from the benchies, it looks like nothing's changed. Time for wiping on three hard drives!
For reference, the day ~2 benchmarks for the 320 and 360GB:
I'm doing the wiping in the exact same way, with three copies of copywipew running in parallel. The wipes are being performed on the 320GB desktop, 360GB desktop, and 120GB mobile drives.
Old February 7, 2011, 05:49 PM
Default Day ~4
After sending about 60 TB through the HDDs in the wipe operations, I don't notice any degradation:
Anyway I'm stopping the HDD wiping experiment, since the way I'm stressing the drives, they'll probably give out before the P67 will...
Note that I am not saying the problem doesn't exist; in fact I read one post in the Anandtech forum in which the OP says his/her SATA2 can no longer recognize drives. What I can say is that whatever the fuse on this Cougar Point bomb is, it's not short enough to blow out your I/O controller with certainty after a few days of HDD wiping.
If you have other suggestions I'll give them a try. Don't tell me to raise voltages because I think it's unrealistic to do so. (It's like saying you can simulate long term on a car by exceeding its towing capacity for one trip - the stresses are all different.)
Old February 7, 2011, 06:25 PM
ZZLEE's Avatar
Try DJ music files.
saw post that a laptop used mostly froe DJ music fore 3 months steady crapped out on a guy.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Kingston 64GB V Gen 2 SSD not hitting good r/w numbers can you help CoolHandL Overclocking, Tweaking and Benchmarking 11 May 13, 2010 11:42 AM
EVGA GTX260 hitting 85-90C temps? bushwickbill Overclocking, Tweaking and Benchmarking 8 March 14, 2010 12:42 PM
Feser One 6 months experiment Dazmode Water Cooling 11 December 29, 2009 11:35 AM
How to dye water cooling tubing *Experiment*IKIKUINTHENUTZ IKIKUINTHENUTZ Water Cooling 3 September 19, 2009 05:35 PM
Opteron Experiment xrmarcis CPU's and Motherboards 8 September 24, 2007 12:44 PM
