-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   OCing Help (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/40397-ocing-help.html)
Finkswitch February 1, 2011 06:42 AM
OCing Help
So, this is my first post here, but I've been lurking the forums for a while now.
I'm running a Phenom II X4 965BE on a Crosshair IV Formula, and I'm having some issues OCing it. I've got it stable at 4.0GHz, but that's @ 1.5v, and after 9 hours of Prime95, the temp capped at 63C. I just got a Corsair H70 and installed it last night, so those temps are running that. Here's what I'm running at: (Keep in mind, I'm going from memory right now)
Phenom II X4 965 BE (125w)
Multiplier: 19
FSB: 210
If I try to OC it any further, I'm getting bluescreens within seconds of running Prime95. The bluescreens lead me to believe that it's voltage issues, but I'm already running rather high. I'd love any advice that anyone could give me.
jibz February 1, 2011 10:50 AM
I don't like running deneb chips over 1.45v as the aren't suppose to run over 63c. I think I was able to get my old 965 to 4.1ghz at 1.44vcore.
Finkswitch February 1, 2011 10:58 AM
The issue I'm having is it bluescreens if I lower the voltage below 1.5. I'm at a little bit of a loss as to what to modify, as I'm sure there's a way to get it up over 4GHz without such high voltage.
LarkStarr February 1, 2011 11:49 AM
have you bumped up the northbridge and PLL voltages too?
Finkswitch February 1, 2011 12:09 PM
It's stable with the NB on auto (I think it goes around 1.2v) with the CPU at 1.5v. I'm not sure what the PLL is, I'm a little new to the whole OCing scene.
LarkStarr February 1, 2011 12:27 PM
you need to boost that NB for sure.
the CPU-NB setting and the VDDA Setting needs to be boosted as well, also, what is your ram voltage, speed and timings?
have you looked up overclocking resources on google?
Finkswitch February 1, 2011 12:55 PM
I'll try boosting the CPU-NB voltages when I get home. I'll check what the VDDA settings are and boost them as well. My RAM voltage is set to auto, so I'm going to check that as well, but the timings and speed are set to the manufacturers settings.
I've done a bit of searching, which is how I got as far as I did with this endeavor, but I'm starting to hit a wall with what I can do on my own.
LarkStarr February 1, 2011 01:00 PM
well that's part of your problem then. you can't keep the ram at stock while overclocking and you need to boost your other components.
You gotta give juice to everything else, and underclock your ram to compensate for the overclocking of the motherboard.
Finkswitch February 1, 2011 01:46 PM
So you think the issue might be the RAM is clocking too high then? I'll try underclocking the RAM and see if that helps...
cul8erppl February 1, 2011 02:02 PM
^^^ That should help. It did for me, and that was my main problem, as i was able to keep my voltages rather low (but then again, i'm only at 3.25 GHz from 2.6GHz).
