Old December 11, 2011, 08:52 AM
ur unicore is to high for hexicore cpu. For quad core cpu unicore is double the ram speed for hexicore cpu u need to set it at 1.5 times ram speed. Do a search on unicore setting for hexicore processors
intel 980@4500mhz
gigabyte x58a-ud5
24 gig of gskill sniper 1600
triple and double rads
dual serial d5 pumps
3x27 in asus lcd
dual 6970's ek blocks
corsair 1000w
mm case
Old December 12, 2011, 01:58 PM
up your vcore on cpu and drop your unicore
6 core chips can't have a uncore of double the ram speed
double the ram speed for unicore is for quad core cpu, hexicore require 1.5 times the ram plus a stepup of one hit or two
running mine at 1.5 times the ram speed plus one. Two will work also but don't know how tight that is but i know i crashed at times 2. Also might need 1.26 or 1.28 on the qpi/vtt
Also watch your temps supposedly the default heatsink set to high speed is supposed to be good cooler for 980 chip.
Can't comfirm that because i'm running water
intel 980@4500mhz
gigabyte x58a-ud5
3x27 in asus lcd
corsair 1000w
mm case
Old December 12, 2011, 02:01 PM
oops just saw your trfc is set to 88 thats to tight for profile1 on the ram set trfc to 110 in ram subtimings
intel 980@4500mhz
gigabyte x58a-ud5
3x27 in asus lcd
corsair 1000w
mm case
Old December 12, 2011, 02:10 PM
QPI/VTT Voltage.......................1.580V you don't need newhere near that for qpi/vtt set it at 1.26 or 1.28 and keep it within .5 volts of your ram voltage or u'll burn out the memory controller on the cpu. so your ram voltage set at 1.6 and qpi/vtt set at 1.26 or 1.28. then u can up the the cpu speed and cpu voltage. I got mine set at 1.26 on the qpi/vtt 1.58 on 24 gigs of gskill sniper ram cpu multiplier of 23 with 200 on my cpu but thats for a speed of 4700 mhz which u will not be going that far. Do not jack up the qpi/vtt and drop the unicore down to 1.5 times your ram speed you can try one step up above the 1.5 speed and do more reading b4 you begin.
intel 980@4500mhz
gigabyte x58a-ud5
3x27 in asus lcd
corsair 1000w
mm case
Old December 13, 2011, 02:59 AM
I don't like CPU PLL on autos
Performance enhance on std for now
Ram primary timings on their appropriate numbers for your ram.
Ram Secondary timings on Auto
In any case post over in Tweaktown's Gigabyte forums and ask for help.
Fill in a template their
Some guys over their know the Gigabyte boards well
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
UD9, 980X, 5970+5870, 12GB watercooled upgrades almost done shane_p Case Mods, Worklog & Gallery 7 July 23, 2010 11:07 AM
GIGABYTE TOP X58A-UD9 with Intel Core i7 960/980X OC Performance Review windwithme Member Reviews 10 July 5, 2010 07:37 PM
Overclocking on air soulicro Air Cooling 8 April 7, 2010 09:50 AM
My i7 Overclocking Experience - Air Cooled keto Overclocking, Tweaking and Benchmarking 10 July 23, 2009 05:53 PM
