Old January 9, 2008, 08:28 PM
Default TAT vs Coretemp?
Hi guys, I was just browsing extremetech and I noticed a lot of people were using TAT to record their cpu heat. The thing is, TAT gives me much lower results than coretemp. TAT maxes out at 44C under load, while coretemp gets around 58C. What's going on there? I'd think the actual intel utility would be the most accurate...
Old January 9, 2008, 08:39 PM
Babrbarossa's Avatar
They measure the temp from different loci which generally read 10 to 15 degrees different so your readings look about right. the rule of thumb is to stay below 60 or sp using CoreTemp, but below 47 or so on TAT- so with that in mind, either one is OK- unless you're using Vista of course
Old January 9, 2008, 08:46 PM
Thanks a lot. Looks like my temps are ok then, though I don't have much headroom left. I think I got the overclocking bug, I want to push that baby HIGHER DAMNIT! *cough*
Erm, I wonder if I could convince my gf that we should splurge $300 on some water cooling setup... But baby, it's for science! Honest!
Old January 9, 2008, 09:20 PM
donimo's Avatar
just a general vista knock, or actual issues in temp readings with it?
also, funny how I asked this exact question like a half hour ago in my other post... WEIRD!
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old January 9, 2008, 10:07 PM
3.0charlie's Avatar
3.8 on your CPU is quite respectable! And do I hear a future folder for the FAH Team?
Hydro-Quebec is salivating...
