Old January 25, 2011, 10:19 AM
Fudd Rucker's Avatar
Default i7 970 voltages
hi guys,
Just wondering what the max voltages for the 970s are for 24/7 use? I started monkeying around with mine and gotten it up to 4.2 no prob so far , just need to know what limits I can go without breaking this chip.
I couldnt think of something snarky or interesting to put here this time around.
Old January 25, 2011, 10:28 AM
Arinoth's Avatar
As with all other 1366 chips you shouldnt be running higher then 1.4V
Here I am: here I remain
Old January 25, 2011, 11:02 AM
with bloomfeild upto 1.5v was ok as long as temps were ok
with gulftown i would't go over 1.42v for 24/7
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Overclocking i7 920 D0 voltages G777 Overclocking, Tweaking and Benchmarking 13 April 14, 2010 09:35 PM
Overclock + Voltages Jake_HT Troubleshooting 6 February 6, 2009 12:09 PM
Weird PSU Voltages...is this OK? Oversized Rooster Power Supplies 7 October 21, 2008 04:25 PM
Older E8400 OC Voltages rjbarker CPU's and Motherboards 20 September 20, 2008 10:25 AM
Rookie OC'er...Question Re: Voltages rjbarker Overclocking, Tweaking and Benchmarking 9 March 24, 2008 01:10 PM
