finally started to o/c my build today (built in September) and having trouble finding the general "this is the optimal 930 settings."
I know for the 920, people had hella problems with the 20x multiplier and that using a higher bclk and lower memory multiplier reduces the QPI/VTT voltage requirements for stability.
Also, you shouldn't go over 1.35 QPI/VTT and 1.65 vdimm (and you shouldn't have more than 0.5v difference between the two!). Most people also seem to hit 4Ghz with less than 1.3v vcore and you shouldn't push above 1.4v vcore (although gigabyte suggests anything under 1.55v) for longevity.
Well, that's about all the standard things I know.
So, anyone know:
-Most 'friendly' multiplier at hitting +3.8 Ghz with keeping voltages in check? (espeically QPI/VTT I don't want to exceed 1.35).
-Optimal settings to find my max bclk without going over 1.45v vcore and 1.35 QPI/VTT?
-Anything else I should know about the 930?
I'm optimistic that I can reach the same 4.3 Ghz on air that they did with their CPU but with lower voltages through a higher bclk (a few people with the same mobo reported 220 bclk without insane voltages)
Review - Intel Core i7-930 CPU Review | bit-tech.net
I'll just cross my fingers that I got a special 930 :)
