-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   My overclocking adventure begins... right meow. (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/39786-my-overclocking-adventure-begins-right-meow.html)
D4ng3r January 11, 2011 12:04 AM
Hey guys, I have a computer waiting to be boosted through some nice overclocking.
Running in my rig now is:
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz (under water :ph34r:)
GFX: ASUS HD 5850 (went for the one with better stock cooling, this beast is made for overclocking)
MOBO: P5Q3 Wifi-Deluxe
RAM: G.SKILL Ripjaws 8GB (2x4GB) DDR3 1600 (pc3 12800) (timings are 9-9-9-24, stock.)
Just got the RAM in today, and have decided that I'm not going to wait to buy a SSD before I start my overclocking adventure. Not that it matters... :offtopic:
My question for you guys is this
: What do I start with? I know I can find lots of articles out there on HOW to overclock (I know the basics, and will gladly do the research and learn more). I just haven't been able to find a site that tells you WHAT to start overclocking first. I take it I want to OC something, get it stable, and then move on... but is there a chance that I would get higher clock speeds by having other components running faster too? Does that mean that I overclock an item, move on, and then come back to it to see if I can get a bit more juice out of it?
Thanks for the replies. This is my baby, I want to do this RIGHT! :canadianwave:
Dan
_dangtx_ January 11, 2011 12:19 AM
if youre lazy like me? drop ram on a divider, lowest you can if you wish, and start cranking up voltages a bit and fsb it up
till prime95 fails right away or almost. then add a bit more juice till it doesnt fail anymore, at least after 10-15 min,
add some 3dmark looping and if its still ok keep pushing. disable the auto features in the bios, it sometimes screws with ya clocking :)
ZZLEE January 11, 2011 12:36 AM
Overclocking is a jurny of discovery. :)
I haven't clocked a 775 other than ASUS software clock.
And double threading a P4 :) and a 200 :)
Look here http://www.hardwarecanucks.com/forum...ols-trade.html
Image your drive ( disk Image )
Find out how to get in to BIOS fore your bord usaly 'deleate' Key oon start up
D4ng3r January 11, 2011 01:07 PM
I dont think you guys quite understood what I was trying to ask; I wanted to know which component you usually start a whole-system overclock with. :)
enaberif January 11, 2011 01:13 PM
CPU.
As that will pretty much change most settings like your ram dividers and etc.
D4ng3r January 11, 2011 02:28 PM
Originally Posted by enaberif (Post 473324)
CPU.
Thanks, good place to start.
