Old December 13, 2010, 10:15 PM
Blu's Avatar
Blu Blu is offline
Default Think this is overclockable?
I overclocked my old pc a evga 680i with a dual core to 3.2ghz but I never thought about overclocking my current pc. It's not really high end or anything just the basics really, here's what I got:
Q9400 2.66Ghz
Gigabyte EP45-UD3L Motherboard
And 4GB Ram *not sure on the timings or anything really*
Think I would be able to oc this to about 3.0ghz? I have gotten the odd BSOD which I've googled and it's said my memory could be hitting the bucket (need to run memtest on it) I've got a massive heat sink as well and my cpu is 40c under 50% load throughout the whole day. What would you suggest I try for a overclock at first and work my way up? I'm pretty noobish when it comes to overclocking though, with my evga I just upped the FSB a little bit and ran prime 95 for a day and it was ok. Thanks guys.
Old December 13, 2010, 10:23 PM
SugarJ's Avatar
Absolutely it's overclockable, as long as your memory can take it.
Old December 13, 2010, 10:24 PM
Overclocking a 680i? Asking for trouble!
Old December 13, 2010, 11:10 PM
He's not overclocking a 680i though, its a p45....
Old December 13, 2010, 11:12 PM
my q9400 runs at 3.45 ghz. memory is holding it back for sure.
Old December 13, 2010, 11:51 PM
Blu's Avatar
Blu Blu is offline
What are your voltages and fsb?
Old December 14, 2010, 12:48 AM
I've clocked mine clocked to 3.2
Old December 14, 2010, 01:39 AM
sorry, Im tired. MOTHERBOARD is holding it back. FSB is 433 (one mhz higher = LE CRASH!) voltage is 1.47, the (P.O.S) mobo droops to 1.44.
Old December 14, 2010, 05:39 AM
looking good. first of all, get some airflow over the mobo, then drop multi and cranck the fsb while having the ram on lowest divider. and then you worry about bringing the cpu multi up. take it easy with the juice
overclockable ram mo' power Overclocking, Tweaking and Benchmarking 5 August 11, 2010 10:47 PM
Intel Rumoured to Release Overclockable Core i5 & i7 CPUs FiXT Press Releases & Tech News 21 March 22, 2010 10:47 PM
Are 4GB DDR2 Ram Kits even overclockable? decivox RAM 7 February 28, 2009 10:07 PM
New overclockable MB for e4500 Gerrich Overclocking, Tweaking and Benchmarking 7 April 10, 2008 07:46 AM
l/f am2 overclockable motherboard, amd 6400+ BE 3.2 Rapid-X Buy/Sell & Trade 0 February 14, 2008 01:36 PM
