Old December 6, 2010, 09:58 AM
Default Safe Voltages for Core i3 540?
Hi Guys,
Anyone know the safe voltages for a Core i3 540? I've got mines at 4.41GHZ (Prime 95 Stable - 9Hrs) I want to push it further but I'm worried about what the safe voltages are for this processor..
If anyone knows, it would really help me out :)
Thanks!
Old December 6, 2010, 12:23 PM
rjbarker's Avatar
Just go to the Intel Home Page and look it up ......they'll have spec sheet for that Processor, with all Recommended Max Voltages.
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old December 6, 2010, 01:06 PM
Intel® Core
for the lazy :p
that 1.4 is on air.
Old December 6, 2010, 02:58 PM
I've heard guys going as high as 1.6 on the i3s but I can't see that being 24/7 voltages but from my research on the chip while I was deciding on which 1156 to buy that it even does 1.5 easily and safely but of course going outside of Intel's specs is at your own risk.
Old December 6, 2010, 03:03 PM
rjbarker's Avatar
Intel® Core
for the lazy :p
that 1.4 is on air.
Thanks Dan ....I was too lazy to provide the link.....
Old December 6, 2010, 03:51 PM
no worries :p
stock cooler ~1.4 is ok. ~1.5 you need like a cm212 or close. ~1.6 or more on water or if you dont care. trouble is some of the lower end h55/p55 boards dont do too well above 1.4.
good part is these chippies are made to take a beating, so go for it!!!
Old December 6, 2010, 04:10 PM
gingerbee's Avatar
clarkdale's i wouldn't go above 1.4 on air at all remember the core is 32nm Electromigration is easier to do then on 45nm justmy2cents. only the gpu and imc are 45nm. i was able to get mine as high as 4.4 4.5 under safe voltage so do you really need any more.
Old December 17, 2010, 04:40 PM
Thanks for response guys, lol I totally forgot about this thread :P I am using an aftermarket cooler, and I've decided to leave it at 4.41GHZ for now.. I feel tempted to push it further, but I'd hate to have it die on me :P..
Intel Core i3-540 Review Comment Thread SKYMTL CPU's and Motherboards 17 January 11, 2011 11:24 AM
Safe folding@home 24/7 voltages for i7 chrisk Overclocking, Tweaking and Benchmarking 17 January 2, 2011 10:15 AM
i3 540 for gaming Pidg76 CPU's and Motherboards 7 March 26, 2010 10:42 AM
Overclock + Voltages Jake_HT Troubleshooting 6 February 6, 2009 11:09 AM
