Old December 5, 2010, 09:41 AM
Slappa's Avatar
Default 5GHz Phenom II X6 1090T Cold Air
5GHz On Phenom II X6 1090T Using Cold Air Slappa's Blog
Hey guys
Taking advantage of winter, I just broke 5GHz with cold air on my 1090T.
Enjoy
YouTube - 5GHz Phenom II X6 1090T Using Cold Air
5GHz Core #1, 3000NB, 2000MHz 7-9-6 Ram
CPU-Z Validator 3.1
[/CENTER]
Old December 5, 2010, 09:47 AM
Very impressive, but I'm confused. Why does it say 4 cores 4 threads if its a X6?
Old December 5, 2010, 10:15 AM
gingerbee's Avatar
did you turn off 2 cores?
Old December 5, 2010, 06:32 PM
Slappa's Avatar
Yes, I disabled 2 cores.
I only clocked my best core, core #1.
Disabling the worst cores can help with stability when pushing to the absolute max.
Old December 5, 2010, 08:08 PM
that's what I did. disabled 4 cores to get my 1055 up to 4.3 on (warm?) air - pretty sure it can go higher, I'm thinking the mobo is limiting me.
Old December 6, 2010, 03:33 PM
Slappa's Avatar
Keep pushing. What mobo do you have?
High Performance ITX Platform Review-Intel Core i5-655K Air Cooling to 5GHz windwithme CPU's and Motherboards 13 December 11, 2010 10:04 AM
Intel LGA1155 i7 2600K w/ Biostar P67 achieve 5GHz Air cooling windwithme Overclocking, Tweaking and Benchmarking 8 December 7, 2010 09:37 AM
Price drop on Phenom II X6 1090T Delavan CPU's and Motherboards 16 November 5, 2010 10:00 PM
Cold Canadian Air... frosty Air Cooling 4 December 28, 2008 02:02 PM
Phenom FX @4ghz beats 5ghz kentsfield Cheator Rumor Mill 25 August 31, 2008 01:41 AM
