Old December 5, 2010, 08:50 AM
Arinoth's Avatar
Originally Posted by chriskwarren View Post
Yeah I agree that most folks seem to get 4.0 best by using 21x190 (its what I used for that chip on my old board), but when I had that prime worker threads would get error after about 10 mins or so. Going with 20x200 got me from 10mins to about 7 hours, so I kept it. The Rampage is supposed to have good bclk, so that was why I tried it.
No chris, I was refering to using 19 x 210 as i seem to find that runs a hell of a lot more stable and require less voltage.
Here I am: here I remain
Old December 5, 2010, 08:57 AM
chrisk's Avatar
Folding Captain
My ram is rated at 1600...would I have to OC the ram to get 210 BCLK?
Fold for team #54196
Old December 5, 2010, 09:04 AM
Arinoth's Avatar
My ram is rated for that as well, i just run it at 1.64 (can't run 1.65 on my mobo) with it barely overclocked (1680 due to changing the ram multiplier). I think your ram should be able to handle that very minor overclock to it as at least mine has no issues with it.
Old December 5, 2010, 09:15 AM
Sagath's Avatar
even more so if you loosen the timings up to 8-8-8.
And to expand on Sams point, I know it took me weeks to figure out that my rig was more stable at 190x22 then it was at 200x20. But I guess this really doesnt make you feel better about the difference between the P6T and the Rampage...
Maybe the P6T has better regulation, and thats why you've had to change the voltage? Who knows...
Old December 22, 2010, 11:30 PM
chrisk's Avatar
Folding Captain
Originally Posted by Kriegs-Maschine View Post
bahh folder
You must have something to sell??? Lots of 'cool', 'bahh' posts etc etc.
Old January 2, 2011, 12:57 AM
I know that 1.4v for the CPU voltage is getting into the danger zone (for i7). Anything below the 1.4v is usually considered to have minimal impact on the life of your chip (unless you want to keep the chip for 5 years). Obviously 1.65 is maximum for your RAM... Although some people have pushed that limit a tiny bit, others have destroyed their very expensive stuff by over-volting RAM past that limit. I hope I'm not repeating too much, but I will re-iterate that a higher bclk with lower multiplier will provide lower temps and usually lower voltage requirements.
Also, you can download a program from the standford F@H page that does a stress test based on F@H FP calcs to use instead of PRIME if you want. Really though, you will get 5x better folding and PPD results by buying a GT 430 for $70 and using that to fold (unless you're already running 4-way). Also, make sure you leave HyperThreading enabled as that increases your PPD by more than any potential o/c from disabling that feature.
Old January 2, 2011, 10:57 AM
Just as a comparitive reference for you Chris, 24/7 folding on my I7 with stock cooling
Asus Probe II values at ambient 19C
BLCk /Multi 175.5 x 24 = 4284 MHz
QPI Link 3213.1
Dram Frequency 892.5 with 6 sticks.
NB 3570 Mhz
1.36 CPU Vcore 66C @100%
1.40 CPU PLL
1.36 QPI/Dram
1.65 Dram Bus 34C
1.11 ICH 50C
1.11 IOH 47C
1.8 CPU PLL seems to drive the ICH temps high if you leave that voltage setting at "Auto"
Code:
Old January 2, 2011, 11:15 AM
chrisk's Avatar
Folding Captain
Running 970s with core at 1.29 one rig, 1.3 on the other. Set the vdimm manually, and 1.35 qpi volts on both. Left the rest at auto, LLC enabled.
Getting max temps at high 50s folding right now, and mobo temps max at low 60s. I have seen low 60s on the cpu cores while using prime.
Folding @ Home F.A.Q. Supergrover HardwareCanucks F@H Team 229 May 15, 2010 08:24 PM
Folding@home with WHS p3t3rson HardwareCanucks F@H Team 8 February 10, 2010 06:07 AM
Folding@home electricity use Perineum HardwareCanucks F@H Team 103 November 13, 2009 02:17 PM
Folding at home questions slisgrinder HardwareCanucks F@H Team 7 April 16, 2009 05:12 PM
Is my O/C (temps and volts) safe for 24/7 folding? divertiti Overclocking, Tweaking and Benchmarking 10 January 5, 2009 07:45 PM
