Old December 1, 2010, 02:20 PM
Default AMD X6 1055T and MSI 890GXM-G65
My current build:
AMD X6 1055T (OC @ 3.5 ghz)
MSI 890GXM-G65 Motherboard
Corsair 4gbs 1600 ram
This was my first overclocking build and I'm still playing around with the bios settings conservatively.
My main questions are what limit should I try to reach with my core speeds and how should I overclock the ddr3 ram?
I was wondering if any other overclockers had my motherboard or anyone with any suggestions on overclocking this board?
Old December 2, 2010, 01:41 PM
I'm no pro OCer, but I can give you the typical response: As high as you are comfortable with. Some people will say that the highest you can get is worth is, regardless of temps/volts. Some people dont raise volts at all. Lots of people fall in between. You have to find what degree you fit in.
Also, not all chips OC the same. Just because Jimmybobjoe got to 5GHz it doesn't mean that you will get that, even with identical parts. Some just happen to be better OCers than others.
Old December 2, 2010, 03:49 PM
ZZLEE's Avatar
What cooling are you using? the higher the temps usualy the shorter life span of parts.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Tags
890gxm g65 , amd x6 1055t , msi , overclock
[FS] Intel i5 750 for AMD 1055T-1075T mattlef Buy/Sell & Trade 9 October 5, 2010 07:39 AM
[FS] PowerColor 5870, 1055T, LG 20" LCDs, MSI 390FX, MISC. Aix Buy/Sell & Trade 12 September 17, 2010 09:49 PM
GIGABYTE GA-890GPA-UD3H vs MSI NF980-G65 Difference? BiLLiO333 CPU's and Motherboards 7 August 10, 2010 04:55 PM
AMD 955 or 1055T? jcmaz CPU's and Motherboards 7 May 17, 2010 07:55 AM
MSI 790GX-G65 ATX Motherboard Chris CPU's and Motherboards 4 April 18, 2009 05:26 AM
