  #21 (permalink)
Old November 21, 2010, 09:33 PM
ImmaPC's Avatar
Okay, based on this first gamut of answers:
- I will begin by testing out my 480 at a *relatively* low, definitely stable OC, something like 800/1600/2000. Then, get Furmark, Vantage, test, see where temps are, then raise memory OC and see how high I can go with PURELY memory OC before freezing/crashing/etc. I will get a number or a small range from this.
- Then, I will test GPU/Shader clocks against those numbers, see performance with this, potentially higher memory from higher GPU clock, don't know but it's all experimentation.
- Thinking of buying a CM V6GT cooler. After that comes I'll run the hell out of it and see how I can OC, of course only within stable ranges. Then go back to GPU, see how that goes.
3DMark Vantage and FurMark will be basically what I'm gonna be using to test. As for CPU stability, the usual Prime95 should work.
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
  #22 (permalink)
Old November 21, 2010, 09:59 PM
rjbarker's Avatar
^^^^ Sounds good ;) Keep us posted...i'm looking forward to getting my 580's next week (I hope next week) .....
Firestrike Extreme: 21.452
MARK 11: 32.530
  #23 (permalink)
Old November 28, 2010, 01:32 AM
ImmaPC's Avatar
Quick update - Bought a Hyper 212+ because it was on sale for $20 and is a damn good cooler to boot, So I opted for that over a V6 GT. Next time I decide to upgrade cooling *will* be W/Cing, if not *AT LEAST* a Megahalems. Tonight I'm gonna start OC'n CPU; I'll probably do GPU later tonight or tomorrow. As for now, the 212+ works great. Stock speeds, running Prime95 Large FFT's and it's running at <60C on all cores (closer to mid 50's), and idles in low 40's. Using some MX-4 as thermal paste. I dunno about my TIM job, it was my first time on an HDT cooler. I'll experiment with different thickness/applications/amounts or whatever later. Also, I noticed it sits a teensy-weensy bit crooked on my CPU, I'll have to fix that later. For now though, it freakin' WORKS.
GPU RESULTS WILL BE IN MONDAY NIGHT LATEST. Sorry, I got homework to worry about and a job to buy plastic and silicon to add to my heap of plastic and silicon, as well as fuel for my damn car.
Side note - Waiting until after Christmas for 580's. Hopefully catch one on boxing day?
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
  #24 (permalink)
Old March 12, 2011, 11:31 PM
Trial Member
Just wondering, what cooling are you guys using to keep your GPU's so darn cool? As soon as I put my 480 to 1.05v and run Kombustor stability test, 32XQ AA and Direct3D 11, within 2 minutes I am sitting at 91C. It idles at about 48C-50C. So I am really wondering how you guys keep your cards so cool.
  #25 (permalink)
Old March 13, 2011, 06:36 AM
gpus loves water
gtx 480 with gtx 260 for physx (power consumption question?) bvsbutthd101 Video Cards 15 July 7, 2010 10:37 PM
Koolance Releases GTX 470 & GTX 480 Full Coverage Waterblocks FiXT Press Releases & Tech News 7 April 9, 2010 07:34 PM
PNY Technologies Unveils GeForce GTX 470 & GTX 480 FiXT Press Releases & Tech News 3 March 29, 2010 03:15 PM
NVIDIA Clarifies Official GTX 480 and GTX 470 Launch Date matsta31 Press Releases & Tech News 76 March 9, 2010 02:07 AM
NVIDIA's Next-Gen Parts Get Named: GTX 480 & GTX 470 SKYMTL Press Releases & Tech News 67 March 6, 2010 09:23 PM
