I have my 2 x 5870s set to 1000 / 1350 right now using Afterburner. Both are flashed to the same ASUS bios. I seem to have a weird problem though.
According to Afterburner, at Idle, GPU2 sits at 400 / 1350 just like it should. But GPU1 idles at 850 / 1200.
Then, as soon as I open GPUZ, Afterburner shows 400 / 1350 for both cards, and with GPUZ open Afterburner changes its readings on GPU1 and shows 400 / 1350 and stays that way for about 10 seconds before reverting back to 850 / 1200.... In a game, everything is just fine @ 1000 / 1350.
Is Afterburner (version 2.0.0) showing the wrong numbers? Or is it actually screwing with my clocks?
ALSO, in the information tab, Afterburner shows GPU1 as being the Master, but GPU2 runs a bit hotter and if I run something like Kombustor, it's GPU2 that is being used and NOT GPU1. Seems weird to me...?
Here you can see where my clocks have changed just from opening and closing GPUZ
Any OC / Xfire experts have any ideas or answers for me? This is my first time running Xfire.
Thanks
