Old November 15, 2010, 03:51 PM
BrianHanna's Avatar
Default what settings for prime95?
After battling with it for a while, i finally got my computer to boot with the following settings
so, how long should i run prime95, and at what settings ( figure at least 12 hours, but i'm not sure about the settings)
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old November 15, 2010, 04:29 PM
3.0charlie's Avatar
Simply let it rip, "Blend" settings. 12 hours would be fine for me.
Old November 15, 2010, 04:36 PM
I usually use Linx for a quick analysis for the correct voltage. Run 3 runs at max memory and insure that each run passes with gflops greater than the previous.
Then continue do a 20 runs of linx (1 to 1 1/2 hrs), once pass run overnight tests. Either Prime95 blend or 100 Linx runs.
BTW those are great voltages for 4.2 if that is stable.
Good luck
Old November 15, 2010, 05:15 PM
I find that small FFTs will give me BSODs sooner than blend tests, but each to their own. Blend tests are probably much more thorough, but I just want to know if I'll get blue screens or not.
Old November 15, 2010, 05:16 PM
ZZLEE's Avatar
Ehat cooling ? If your on stock your going to have heating isues BIG TIME.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old November 15, 2010, 05:20 PM
blend works more on memory.
smallfft works better on cpu
Old November 15, 2010, 05:52 PM
He's on a aftermarket cooler.
Noctua NH-U12P which is pretty decent.
Old November 15, 2010, 06:18 PM
ZZLEE's Avatar
Ya didint see it at first. It is still were I expect problem on like 24h run on prime95.
Old June 2, 2012, 04:23 AM
So "Small FFTs" is the most intensive CPU test in Prime 95? I want to use the most intensive test to give me the confidence that my overclock is indeed stable.
I suppose if it is stable after 24 hours or so, I can use blend and will blend stress out the motherboard in addition to the RAM? I also want to make sure the RAM is tested for stability as well.
Old June 2, 2012, 04:28 AM
Newest version is 27.7 build 2 stresses the instruction set avx more
Tick both boxes in advanced for round off and error checking.
Cambridge,ON
MSI Z77 M Power/Bios17.7
i5 3570k@4.5ghz
Mushkin #997007
Noctua NH-D14
EVGA GTX460
Seasonic X-660
Antec P280
Intel Speed Demon Equipped
using Prime 95 27.9
Prime95 Crash NightRain Troubleshooting 5 May 12, 2010 06:11 AM
Still Crashing Prime95 :( jcmaz Troubleshooting 6 May 7, 2010 08:48 PM
prime95 without cooler! 486 Air Cooling 20 February 11, 2009 10:46 AM
Need some help with prime95 Gameplaywarrior O/S's, Drivers & General Software 2 November 29, 2008 11:16 AM
Prime95 v2.51 enaberif Overclocking, Tweaking and Benchmarking 6 July 25, 2007 08:34 PM
