Old November 14, 2010, 07:25 PM
Default Intel LGA1155 i7 2600K w/ Biostar P67 achieve 5GHz Air cooling
CPU
Intel Core i7-2600K
32nm, 4C8T
MB BIOSTAR TP67XE
Chipest Sandy Bridge - Cougar point
DDR3
CORSAIR DOMINATOR-GTX3 DDR3-2400
CL9 11-9-27 1.65V
System Configuration
CPU: Intel Core i7-2600K
MB: BIOSTAR TP67XE
DRAM: CORSAIR DOMINATOR-GTX3 DDR3-2400
VGA: GIGABYTE GTX260 OC
HD: CORSAIR CSSD-F40GB2 Raid 0
POWER: Antec TPQ-1200W
Cooler: Mega Shadow Deluxe Edition
OS: Windows7 Ultimate 64bit
Default Performance
CPU 100 X 35 => 3500MHz (Idle 1.044V, Full 1.008V)
DDR3 2133.8 CL9 10-9-27 1T 1.5V
Hyper PI 32M X8 => 14m 24.460s
CPUMARK 99=> 539
Fritz Chess Benchmark => 27.53/13212
AIDA64 Memory Bandwidth - 21901 MB/s
OC Performance
CPU 100 X 50 => 5000MHz (Idle 1.452V, Full 1.392V)
Hyper PI 1M => 07.551s
CPUMARK 99=> 770
Fritz Chess Benchmark => 39.25/18839
AIDA64 Memory Bandwidth - 25235 MB/s
This article is also posted in my blog: WIND'S 3C
Welcome 3C fans to drop by.
Old November 14, 2010, 07:27 PM
DorkSterr's Avatar
Nice!
i7 980X @ 4510.5MHz | Rampage III Extreme | Dominator GT 2037MHz 7-8-7-20 C7* | ASUS 6970 945MHz/1460MHz | 2X Vertex 3 120GB RAID 0* (OS) | Corsair AX1200 | Obsidian 800D
Old November 14, 2010, 08:19 PM
SugarJ's Avatar
Note that there is no change in bus speed, all overclocking is by changing of multiplier only. Be prepared folks, if you want to overclock Sandy Bridge processors, you will need a K series chip with an unlocked multiplier.
EDIT: Disclaimer: This is information that I have gleaned from Bit-tech and Anandtech articles only, and I am not privy to any motherboards or information that might be under NDA from our review staff. This is my opinion only, and you all can freely say "I told you so" if I'm proven wrong.
Old November 14, 2010, 08:28 PM
martin_metal_88's Avatar
Nice one as usual again and again WWM!
Damn you're right. This one will be expensive XD ahah
Old November 15, 2010, 02:08 AM
likes the 5ghz on air cooling at pretty decent volts too!
Old November 15, 2010, 08:20 AM
Bao Bao is offline
fapfapfap.
Old November 15, 2010, 09:10 AM
nice. whatwere the temps?
so basically if you want to ok, only the k series will be the ones to get....which means get the cheapest intel made board that can take your cpu without burning up and up the multis?
hope there's a workaround for the big brands like giga and asus...else why would you buy a super oc 300 dollar board when it won't oc a regular non k cpu?
Old November 16, 2010, 12:30 PM
Dead Things's Avatar
Why a 32M pi bench on the pre and a 1M bench on the post? Not stable enough for 32M?
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
Old December 7, 2010, 09:37 AM
Wow that is a good result indeed. Expecially on Air :)
ppl used to use phase cooling to go that high not long ago..
High Performance ITX Platform Review-Intel Core i5-655K Air Cooling to 5GHz windwithme CPU's and Motherboards 13 December 11, 2010 10:04 AM
How to achieve better quality recording (MIC) GameOnTurtle Audio 1 April 26, 2010 06:07 AM
Intelís Latest 32nm Clarkdale Platform - Core i5 661 With BIOSTAR H55 OC 5G On Air windwithme Member Reviews 6 January 15, 2010 08:21 AM
[FS] Intel 2.66GHz (OC 3.5GHz) Core i7 920 DX58SO PC dargpat Buy/Sell & Trade 7 February 27, 2009 05:22 AM
What is better?Air Cooling blogz101 Air Cooling 13 July 9, 2008 03:13 PM
